Is 1.3 rad sufficient
I have a 2.0 zetec in what was once a mk4 1.3 fezzy, will the original 1.3 rad I have be ok or should I get hold of a bigger one? Like say from a 1.8 etc?
Any help appreciated
Dave
Dave
you could use an rs turbo one, one from a later car running on a zetec.
wouldn't be hard to make it fit and pipe it up.
saxo rads are ok, but you have to fit a bleed point high up in the cooling system as they don't self bleed like the standard header tanks.
its a short vad with a wide core plus header tank is built into the rad we did this on the mk1 and im doing this on the escort as the bay is all smooth with no wiring visable
mk3ste
Oct 17, 2021 10:09 AM
liamT74
Sep 23, 2015 10:24 PM
