escos running!!!!
Old Feb 24, 2011 | 06:13 PM
adam escort cosworth's Avatar
Default escos running!!!!
ok this is doing my head in !!!!!!!!!!!!!!!!!!!!!!!!!!! 1992 big turbo escos, it wont rev past 4000 rpm and it sometimes does it (like the spark is being cut off) under light accelleration about 1100 to 1500 rpm ?????? and its fairly intermittant??? help all sensors fairly new, multi plugs have been hard wired (solderd) ???
Old Feb 24, 2011 | 06:26 PM
dangerbrian's Avatar
dangerbrian
try a new set of spark plugs a lad on escortrscosworth.com had a similliar problem to you and it seemed to have cured it
Old Feb 24, 2011 | 06:43 PM
new 071c plugs fitted two days ago!!!! and gapped correctly!!!!
Old Feb 24, 2011 | 06:46 PM
grcossie's Avatar
grcossie
Have you try a new map sensor?
Old Feb 24, 2011 | 06:49 PM
yeh new map sensor, etc sensor, air temp sensor, phase sensor, ignition amplifier, lambda sensor, and a new crank sensor about 6 months ago!!!!
Old Feb 24, 2011 | 09:58 PM
grcossie's Avatar
grcossie
It could be your ecu, it was another guy on escortcosworth forum, whit similar problem, and thats was e ecu problem. He change it, and everything was working perfect
Old Feb 25, 2011 | 07:59 AM
oldford's Avatar
oldford
Have the fault codes read. 4000 rpm is a hard limit when a fault is detected.
Old Mar 3, 2011 | 04:52 PM
kcosneil's Avatar
kcosneil
reset the ecu and see if it sorts it.
Old Mar 3, 2011 | 05:40 PM
tried that mate, and ive put my mates ecu on my car and made no difference!! im just left with the engine loom now which has got some corroded wires to throttle switch and tdc sensor so i geuse thats the problem!!! so ive just ordered a complete engine loom from ryan at carlooms uk!! should have it in a week or so !!! will let you know if it sorts it
Old Mar 5, 2011 | 06:41 PM
liamford's Avatar
liamford
hi mate, i notice with my small turbo cossie if i unplug the air temp sensor it wont rev past something like 2k. dono if the large turbo's have air temp sensor but if it has worth a look?
Old Mar 6, 2011 | 06:35 PM
it is a newair temp sensor but ive still got the old oneso iwill try it bk on there!!! thanks.
Old Mar 7, 2011 | 09:15 AM
MalZon's Avatar
MalZon
Doublecheck if you connected the Cranck-sensor, Phase-sensor and the Knock-sensor right. I had by mistake connected 2 of those on my S Cossi, and did not rev over 4000rpm..
Just a tip!
Regards/Jonas
Old Mar 7, 2011 | 09:35 AM
MannheimAlex's Avatar
MannheimAlex
when my airtemp sensor was dirty(covered with oil) it also went into limp mode. Gave it a clean and it ran fine.
Old Mar 19, 2011 | 08:57 AM
graham c's Avatar
graham c
check your map sensor pipe is not split
Old Mar 19, 2011 | 01:34 PM
ossie cossie's Avatar
ossie cossie
Just a tip!
Regards/Jonas
Found this was the problem on the car i was looking at, however it now wont start at all. something else is f@#ked now.
Old Mar 21, 2011 | 10:58 AM
MalZon's Avatar
MalZon
I would check the gap between the phase and crank sensor.
Regards/Jonas
Old Mar 21, 2011 | 12:55 PM
Stu @ M Developments's Avatar
PassionFords Creator
Check the fuse labeled "Kat"
Old Apr 27, 2011 | 12:35 PM
wally rs's Avatar
wally rs
had this prob on my large turbo escos it was the idle control valve
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
