FAO anyone who has done the clutchpedal mod
Old Feb 23, 2011 | 10:33 AM
white2lsr's Avatar
white2lsr
Default FAO anyone who has done the clutchpedal mod
How the hell do you get the pin out that secures the clutch and brake pedal into the box? I presume you remove the clip and it the goes in the direction of the throttle pedal?? Mine moves about a mil and thats it
Old Feb 23, 2011 | 10:36 AM
chaffe's Avatar
chaffe
Turbocharging Technician
you on about swapping the ratchet from a low throw to high throw one?
Old Feb 23, 2011 | 10:40 AM
white2lsr's Avatar
white2lsr
Yea but i cant get the pin to move
Old Feb 23, 2011 | 10:57 AM
Jimmyc's Avatar
Jimmyc
There's a couple of circlips, pop those out and it should wiggle out.
Old Feb 23, 2011 | 11:20 AM
chaffe's Avatar
chaffe
as above mate, dont sniff the seat
Old Feb 23, 2011 | 11:27 AM
Antti O's Avatar
Antti O
Btw. clutch pedal mod is not always necessary. I am running ap-racing clutch kit with standard pedal setup .. no problems. In fact, clutch mod makes horrible rubber ball feeling.
Old Feb 23, 2011 | 11:29 AM
white2lsr's Avatar
white2lsr
There is one on the left hand side on the end of the pin which I have removed. Where is the other?
Old Feb 23, 2011 | 11:30 AM
white2lsr's Avatar
white2lsr
Ther biting point was about 1cm off the floor and you had to stamp the pedal to the floor to get gears
Old Feb 23, 2011 | 11:41 AM
Jimmyc's Avatar
Jimmyc
The others on the right hand brake pedal side.
Old Feb 23, 2011 | 11:50 AM
Karlos G's Avatar
Karlos G
Balls Deep!
"rubber ball feeling" is because you didnt refit the spring that takes up the slack in the cable
Old Feb 23, 2011 | 12:17 PM
white2lsr's Avatar
white2lsr
Which spring is that Karlos? The one from the quadrant to the pedal? I dont want to make the same mistake.
Old Feb 23, 2011 | 12:19 PM
white2lsr's Avatar
white2lsr
Managed to get it out, thanks for your help.
Have some rep power
Old Feb 23, 2011 | 12:22 PM
Jimmyc's Avatar
Jimmyc
Have some rep power
No worries chap. Cheers
Karlos G's Avatar
Karlos G
Balls Deep!
If you follow the instructions on the AP website it shows using the old quadrant to pedal spring to take up any slack in the cable by hooking it to the side of the pedal box and then the clutch pedal, before i did this the pedal was spongy as fuck! lol
Old Feb 23, 2011 | 12:28 PM
white2lsr's Avatar
white2lsr
Cant find about the spring on their site. The instructions have maybe changed. Does the spring then just hold the pedal all the way out when not applied taking up the play in the cable?
Old Feb 23, 2011 | 03:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Like this mate...
Old Feb 23, 2011 | 05:47 PM
dave_s2_rst's Avatar
dave_s2_rst
the spring is still available from fords incase you don't have one
Old Feb 24, 2011 | 09:11 AM
Antti O's Avatar
Antti O
Karlos, correct. Spring wasnt there.
But i still use stock clutch pedal setup.
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
