cosworth running problems help needed
can anyone help iv got running issues with my saph cos 4x4 , from cold its fine but after bout 20mins of driving it it starts playing up if i slow down in gear it cuts out and at low revs it miss fires and hessitates then stalls it starts straight back up and ticks over fine but as soon as i pull away it starts playing up again ,on boost it runs fine and has no loss in power ,its driving me mad iv made sure all the bolts in the manifold are tight and none are missing ,iv also changed the water temp sensor and made sure the 3 big multi plugs on the bulk head are tight and sprayed up with wd40 .
has anybody got any ideas or come accross this problem any help would be much appreciated .
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
