i no its been up a million times before but gearbox oil
This is what I use http://www.opieoils.co.uk/p-832-silk...-gear-oil.aspx Silkolene PRO SRG 75 Full Ester Synthetic Racing Gear Oil
IIRC you'll get 3 liters in there if completely empty.
Turbocharging Technician
used engine oil will do fine, chances are it will be getting replaced in a month or so anyway
just put anything in it, ep80, atf, ep90, as long as it has oil, the thing that fucks these most is lack of oil, ok, usually cos the diff bearings wear baddly causing all the oil to fall out
, then the layshaft bearing fails after that, if something else hasnt first. good luck
JoeyBoyden
Aug 18, 2015 10:52 PM
