high powered clutch setups
Old Feb 20, 2011 | 12:26 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Default high powered clutch setups
i'm building an over the top zetec turbo engine and will need a clutch to hold 400bhp+
i will be fitting a focus rs box too so that's simple enough.
also i will be buying a brand new flywheel for this so machining isn't needed as such.
however i've been told to get hold of a focus rs clutch cover and use a cosworth six paddle friction plate.
i can't find the clutch cover on it's own anywhere and really don't want to spend nigh on £450 for just a focus rs kit if it's not up to the job.
does anyone have any useful input on this or know where to look for a good deal.
cheers
sean
Old Feb 20, 2011 | 04:54 PM
nevsrevs's Avatar
nevsrevs
excidy do a good clutch and i used a helix 6 paddle that was good @ 350bhp but dont get the light fly wheel, the storys of oil pump failure from crank vibration worry me
Old Feb 20, 2011 | 05:19 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
aiming for more than 350bhp, i just want transmission sorted so i don't have to worry about it if i push the power up and up later.
won't be touching light weight flywheels, gary told me not too, so i won't.
Old Feb 20, 2011 | 05:34 PM
crazycage's Avatar
crazycage
the ap 6 paddle will be fine @400hp mate.
Old Feb 20, 2011 | 05:59 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
thing is i heard the focus cover and cosworth 6 paddle was the best combo, but i've looked into it on the AP site and they both use the same paddle.
weird, prob end up getting the 6 paddle focus one then i guess.
that's a fair whack on a clutch, but if it does the job and lasts, then so be it.
Old Feb 21, 2011 | 07:45 PM
nevsrevs's Avatar
nevsrevs
wat you going for mtx75
Old Feb 21, 2011 | 10:33 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
not understanding your reply.
i'm fitting a FRS mtx75, reason is i'm going to be running more power.
Old Feb 22, 2011 | 08:26 PM
nevsrevs's Avatar
nevsrevs
sorry did not read your first post carefully, good luck with it all
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
RSmark84
Sep 13, 2015 01:29 PM
