Coil
Old Feb 19, 2011 | 12:40 PM
Fezman1's Avatar
Fezman1
Default Coil
Im in the middle of rebuilding my saff, looking for advice on what coil to go for. It will be 360ish bhp.
I understand grpA coil would be best,
but do you get an upgrade coil that looks like the std one?
CheeRS Fraser
Old Feb 19, 2011 | 12:48 PM
col93saphcos's Avatar
col93saphcos
i put on msd's wasted spark,one of the best things i did,
maybe an option for you tho,
colin
Old Feb 19, 2011 | 03:26 PM
The group a is far better than the std coil, but it's a totally different shape, the connectors are different so a seriously simple bit of wiring needed.
Imo coilpack from msd is monumentally overpriced, for near that price you can get another ecu, for a little more a ecu/loom and set up.
The coilpack is NOT a cure all for ignition problems, if even thinking about coilpack the first thing I'd do is ditch the std ecu and go after market, which has coilpack as well as load of other features.
Old Feb 20, 2011 | 10:34 AM
Fezman1's Avatar
Fezman1
Thanks for the replys guys. Yea, i wont be going to coilpack conversion til i go to aftermarket ecu.
Would the likes of the msd blaster coil be as good as the grpA coil?
As it is the 'can' shape.
Like this;
http://cgi.ebay.co.uk/MSD-Blaster-2-...item5adecffaad
Old Feb 20, 2011 | 10:41 AM
boost mad's Avatar
boost mad
I would say a grp A coil and a coil rewire would be the best bet
Old Feb 20, 2011 | 05:09 PM
martysmartie's Avatar
martysmartie
+1 for the Grp A coil, as said it's totally different shape and wiring though, (Looks like a coil pack) although you can use connectors to save cutting your wiring up.
Martin
Old Feb 20, 2011 | 05:34 PM
The msd blaster 2 is massively more powerful than the group a, the msd in this case is nothing to do with msd in blackpool, as you've guessed, I know people who have used the msd blaster 2, to excellent effect, it's a VERY powerful coil, the group a is just a std fit coil on a lancia, but was more powerful than the crap they fitted to the cossie when new, so is still a good upgrade.
Old Feb 20, 2011 | 05:51 PM
Thanasis's Avatar
Thanasis
i already used the msd blaster but it leaking oil from inside almost from new,also made from china...
Old Feb 20, 2011 | 09:28 PM
Papillon's Avatar
Papillon
Add a msd ignition amplifier like the 6a or 6al to your msd coil, this is as good as it gets without binning the dizzy system for wasted spark.
Old Feb 21, 2011 | 04:21 PM
From my experience over the years with this make, that is very unusual.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
beller
Sep 21, 2015 04:13 AM
