Non Ford parts & other stuff for sale If its not for a Ford, or even not car part... this is the room to sell it!! Starting a topic requires you to have purchased a gold membership.
Aeromotive Eleminator kit for sale
Old Feb 18, 2011 | 12:14 PM
szabyk RST's Avatar
szabyk RST
Default Aeromotive Eleminator kit for sale
running less than 1000 miles
price drop 500 delivered
eleminator pump :
1104 - Eliminator Fuel Pump
SKU: 11104
This continuous duty “street warrior” supports big horsepower and maintains the drivability necessary for a true high performance street car. Designed for high horsepower street/strip applications, EFI or Carbureted, it features our “dual chamber” pumping mechanism.
Fuel Injected Engines:
up to 1900 HP – naturally aspirated
up to 1400 HP – forced air induction
Carbureted Engines:
up to 2300 HP – naturally aspirated
up to 1700 HP – forced air induction
• ORB-12 inlet port and ORB-10 outlet port.
• For EFI applications use regulator P/N 13110, carbureted P/N 13212.
• Fully submersible for custom, in-tank placement.
• 25% more flow at pressure than our A1000 Fuel Pump.
• Perfect for “blow-through” carbureted engines up to 1700 HP.
regulator :
SKU: 13101
Performance EFI regulator designed for medium to high horsepower applications. This regulators features Aeromotive’s high-flow design, superb pressure control and legendary durability. On the street and at the track, this pressure regulator has logged more miles, laps and passes than any other performance EFI regulator in the world!
• Base pressure adjustable from 40-75 PSI.
• Gasoline and alcohol compatible.
• Fuel pressure rises on a 1:1 ratio with boost.
• 1/8” NPT gauge port.
• P/N 13101 provides (2) ORB-10 inlet ports and (1) ORB-06 return port.
filter:
12301 - 10 Micron, ORB-10 Red Fuel Filter
SKU: 12301
An inexpensive insurance policy to protect your investment.
Proper filtration is key to fuel system performance. Engineered filter solutions are required to achieve protection with minimum restriction. For 200 – 3,000 plus HP applications, our filter assemblies offer unmatched flow, ease of installation and maintenance, along with the impeccable machining and finish you’ve come to expect from all Aeromotive components.
• High-flow, 10-micron fabric (fine) replaceable element.
• Flows 2,000 lb/hr with a pressure drop of less than 1 PSI.
• Compact size: 5.5” long x 2” diameter
• ORB-10 ports. Fittings available to adapt these filters to AN-10, -08 and -06 line sizes. (see Fittings & Adapters)
• All filter assemblies feature an O-ring for positive sealing in high pressure applications.
• CNC-machined from 6061-T6 aircraft aluminum.
• Bright dip red anodized finish for a corrosion resistant, show car quality appearance.
Old Feb 21, 2011 | 06:34 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
How much for the fuel filter posted to the UK mate?
Old Feb 22, 2011 | 03:37 AM
szabyk RST's Avatar
szabyk RST
hello,
I'd like to sell stuff in the kit
thanks
price drop
jonfoc
16
Sep 11, 2018 05:35 PM
Bailes1992
Sep 19, 2015 02:17 PM
roomey
Sep 19, 2015 08:40 AM
richierich1986
Sep 18, 2015 03:29 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
