2wd calipers
Old Feb 16, 2011 | 08:41 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
Default 2wd calipers
got a problem with the front brakes stickin on in ma saph a got a set of seals for them from ford how hard are they to chance and will this stop them form grabbin on after they hav been pressed?
Old Feb 16, 2011 | 10:13 PM
cossiedad's Avatar
cossiedad
More likely to be sticky/damaged/pitted pistons I'd of thought. After all, if the seals are perished/damaged they'll of let sh#t into the pistons. I've just had mine rebuilt by Bigg Red. They offer 3 different finishes and 4 colours. Only worked out at £50 labour on top of the parts costs. Here's a few pics of mine
Have to say I was impressed with them. Mine are done to their top option of finish with a polymer coating to resist dirt/dust/oil/brake fluid. Check out their website it's all on there.
cheeRS
Old Feb 16, 2011 | 10:17 PM
wulliesxr4i
GIT-R-DONE
that looks mint mate, so in all wot did it cost u to get that done?
Old Feb 16, 2011 | 10:36 PM
cossiedad's Avatar
cossiedad
£169 for this finish. Plus £10 return postage and had to pay for my own postage to them. I also bought a new set of pad pins and pad retainers for £20 from them. I added it up and it would cost £120 just in bits so, for £50 more, it was a bit of a no brainer. They pressure tested them up to 600psi, new nipples, pistons, seals and coated/painted.
Check out their website as it's all on there. Friendly too when I called up. Base finish is £129 I think and £149 for the mid finish, then these.
Old Feb 16, 2011 | 10:46 PM
wulliesxr4i
GIT-R-DONE
think al need to get this done asap wish a had a spare set a could send off and get done then put them straight on
Old Feb 17, 2011 | 07:38 PM
I'm not sure if big red do it, but you can also use alloy pistons in them like I did with a set years ago, must admit it is on a car that is stood up for months at a time and not a stick in sight, 10 years on.
Big red do a ace job though, I've resealed lots over the years, a lot of the time it has been a waste of time without new pistons, I'm sure they mishape slightly with the years.
Old Feb 17, 2011 | 10:05 PM
wulliesxr4i
GIT-R-DONE
mines was sat off the road for a while now a got it back on the road(november) a hav noticed that if u press the brakes hard the front drivers caliper sticks on ave got a set of seals was goin to see if a could sort them as a temp thing till a get new ones as a use the car everyday
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
