can you repear a 6 long studded block as 1 of the studs came away from block?????
hi peeps,i was tighten the head on the block an whilst tighten on the 85(foot pounds) 1 of the nuts didnt tighten up to the 85,i took the head back off an 1 of the long studs has de threaded from the block,
i was wondering if this could be repaired an if so do u know anyone that could repair it?
