Engine Loom fitting...
Old Feb 12, 2011 | 06:37 PM
cossie04's Avatar
cossie04
Default Engine Loom fitting...
I have here an 88` 2wd Wiring loom here which i am trying to install into a J reg sapphire. Obviously it doesn`t look to be a straight fit, so, can anyone tell me what colours of the loom represent?
Couple of shit pics of the plug...
Old Feb 12, 2011 | 07:24 PM
thin green tacho
red/blue permanent live
black switched live
black/red fuel pump output from ecu
brown/white temp GAUGE
brown/red air con going to relay taped to side of loom on 2wd looms
Old Feb 12, 2011 | 07:55 PM
cossie04's Avatar
cossie04
Thats brilliant mate, thankyou!
I`m presuming the fuel pump wire is a positive, and not a negative? And i don`t have air con, so is the brown/red wire redundant?
big_Rad
Sep 15, 2017 09:36 AM
Marcus L
Aug 29, 2015 02:18 PM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
