Mk1 Focus RS engine cutting out
Old Feb 11, 2011 | 05:49 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
Default Mk1 Focus RS engine cutting out
Just bought a mk1 focus rs and it seems to cutt out when the revs drop approching traffic lights or slowing down for cars, the battery light comes on then it just dies. i have changed the TPS and seems to be better but still doing it, not sure if changing the TPS has helped at all. It seems to do it once the car has been driven hard and temp is up. Its like there is not enough revs to keep the engine turning over, but it idle's fine just below 1000rpm.
Any ideas please?
Ben
__________________
Old Feb 11, 2011 | 05:50 PM
COCHYN's Avatar
COCHYN
Does it have a chav valve?
Old Feb 11, 2011 | 05:54 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
As said, if it has atmospheric d.v. then bin it!
But if not check the crankcase breather hose to manifold line which has a white 1-way valve on it. Prone to splitting.
Old Feb 11, 2011 | 06:20 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
yes its a chavy atmos collins one, i assume a recirc one will do the job, bailey one?
Old Feb 11, 2011 | 07:26 PM
Camel Fiddler
Recirc was factory fitted so would be massive improvement. Choice of valve is yours mate. I have a spare brand new one but as I'm not gold member I can't sell on here so be on eBay.
Old Feb 11, 2011 | 08:41 PM
COCHYN's Avatar
COCHYN
Stay away from silly twin piston dump valve, stick with recirc valves. I had a turbosmart recirc with B.O.V. port, worked a treat and gave a nice release instead of the typical ptssh! sound.
When you do fit them, normally you have to reset the ECU for it to relearn. Simply disconnect battery over night, restart in the morning with all the fans switched on, head lights etc. and allow to fast idle for about a minute or so. You may need to do it once or twice, but it will stop stalling afterwards
Old Feb 12, 2011 | 08:36 AM
focii dan nick's Avatar
focii dan nick
99 focus zetec
my 1.8 did this last year replaced the iacv on the throttle body worked fine since.
its when clutch is pressed it bypasses the throttle body tolet the engine idle... obv no throttle closed throttle body. they are known for getting full of carbon
Old Feb 12, 2011 | 09:37 AM
focii dan nick
99 focus zetec
i think i spelt it wrong it air idle control valve (aicv) no air, no bang!
Old Feb 12, 2011 | 05:43 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
right thanks for the advice lads, really helps.
so what is the best DV to run on the mk1 focus rs then for smooth driving?
cheers
Ben
Old Feb 12, 2011 | 05:44 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
what about this one ???
http://cgi.ebay.co.uk/R-Spec-Recircu...item3364b55b26
Old Feb 12, 2011 | 07:34 PM
hogdog's Avatar
hogdog
I own a 2.0 ESP so I don't know too much about dump valves but on an ordinary 2.0 the symptoms would be exactly the same as having a dodgy idle control valve.
Old Feb 12, 2011 | 07:54 PM
COCHYN's Avatar
COCHYN
cheers
Ben
This one....
http://www.pumaspeed.co.uk/showdetai...?productID=475
Ran perfectly on mine, with a lotta track and road use, never missed a beat.
Old Feb 13, 2011 | 03:43 PM
Rsmat's Avatar
Rsmat
When mine did this i just changed the TPS and it cured it..But thinking about that was when the car was standard when i first got it.
Old Feb 13, 2011 | 03:54 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
i changed the tps mat and never worked, going to try the dump valve now
Old Feb 13, 2011 | 03:58 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
looks good not cheap through!
Old Feb 13, 2011 | 10:13 PM
focii dan nick
99 focus zetec
i dont think a dv would cause it to stall it is just there to keep the turbo running whilst changing gear (dump air due to no pressue from engine)
common symptom from like you say aicv idle control valve on throttle body.
when throttle body closes on idle the control valve opens to let the engine breathe common sense no air no bang
Old Feb 13, 2011 | 10:25 PM
focii dan nick
99 focus zetec
also the speed sensor somewhere on the gearbox may be faulty.i replaced this when my 1.8 was playing up....
Old Feb 14, 2011 | 03:32 PM
COCHYN's Avatar
COCHYN
Common problem on the Focus RS is the dump valve and occasionally the AICV, but after you resolve the stalling issues, wait for the missfire problems caused by either plug gaps or the MAF sensor
Old Mar 26, 2011 | 08:21 PM
Ben BHP's Avatar
Ben BHP
Ive had a collins atmos DV on mine for 2 years now, it never stalls but has developed a mis-fire recently, I didnt realise they were that bad for the MK1 RS Focus?
Old Mar 29, 2011 | 08:30 PM
wootty's Avatar
wootty
"THE BLING MASTER"
Originally Posted by COCHYN
This one....
this is what i have on mine,works a treat and no chaved up noise either.
Old Mar 9, 2012 | 05:31 PM
Putte78's Avatar
Putte78
I got the same problem on my FRS, did you got it fixed??
Old Mar 11, 2012 | 06:17 PM
Lami's Avatar
Lami
If you know what you are doing then clean the icv as its easier than trying to change
it if you dont
My moneys on that, or a split vac pipe.
Old Mar 16, 2012 | 11:02 AM
Putte78's Avatar
Putte78
where exactly is it?, is it hard to clean?
Old Mar 16, 2012 | 10:04 PM
minder's Avatar
minder
hi mate iv just fitted a bailey d v to my rs and had no problems with it and dont sound to loud like some of them do
Old Apr 9, 2012 | 09:39 AM
mpf1987's Avatar
mpf1987
BOOOOSSSST
Is a normal focus TPS the same for the RS?
Old Jun 27, 2012 | 10:42 AM
rs03daz's Avatar
rs03daz
Default icv
if its icv put your air con and and see if it stalls
Old Nov 29, 2012 | 10:19 PM
Smithy23's Avatar
Smithy23
Was this sorted?
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
