Hyper 7 nitro rc car
Full ready to go kit, with race fuel. Very fast, very tough,
Only used 3 times.
Lots of extras fitted like alloy suspension parts and aftermarket exhaust, uprated battery pack,
Runs mint, excellent brakes.
Total bargain as I need the cash and space Ł125.00
Only used 3 times.
Simply drop me a pm, can collect from Blackpool area or get it down to Devon if required. Or I can post via courier as it comes in transportation box
Pm me for details.
pull cord mate, can be converted to electric though, they do a kit
it proper flies along lol, ace for jumping aswell..
I've got one of these with a 5.9cc big block and locked diffs, is a proper little weapon!
http://www.youtube.com/watch?v=H09NqM4p_Fo
As you can see they are awesome fun!
Well itscall ready to go, o got it out and cleaned it today I'd forgotten just how many bits I'd added onto it lol
High torque steering servo, front anti roll bar etc,
Also gas loads of spare suspension parts for when you crash lol
You will want a starter box that turns the flywheel, you can get them for around 30-40 quid. You ideally want one of these and then keep the pull starter on there instead of converting to roto-start, cos if the battery goes flat in your starter, then you can still pull start it.
i personaly prefere pull start,
electric strats are a pain in the arse, why would you want to carry extra stuff around with you,
then you have to make sure the battery for the power start is always charged,
obviously not an issue if its a car based 12v starter but then mobility would be a problem,
pull starts are the best imo
the roto start I found to be a complete waste of time,
the batteries only last a few starts, then if you do get issues with the car and you need to use the starter more often you could end up with a flat starter which would end play,
really mate, stick with pull start. its the most reliable
steerfromdarear
28
Jan 29, 2016 06:14 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
