2wd axle beam
Old Feb 4, 2011 | 07:39 PM
need4speed00001's Avatar
need4speed00001
Default 2wd axle beam
I was wondering if somebody could shed some light on a mixture of answers i keep getting!
Will an L reg granada 2.0 axle beam fit a Cozzy 2wd with 7 1/2 inch Diff?
I only ask as i am breaking one and also need a beam for my 2wd Cosworth.
Are the wishbones the same?
Many thanks for your help
Old Feb 4, 2011 | 10:02 PM
clyde 1800's Avatar
clyde 1800
ive had this conversation with someone before
he said the cradle is the same but the wishbones will set the wheels too far out
Old Feb 4, 2011 | 10:08 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the beam will be the same, the wishbones won't as they won't have the correct bearings in them or have the arb brackets
Old Feb 4, 2011 | 10:42 PM
lee2cossies's Avatar
lee2cossies
Am sure that the beam is different where the diff mounts to it,although you can modifiy the beam to allow the diff to fit.involves a hammer though! The wishbones are totaly different.
Old Feb 5, 2011 | 06:44 AM
need4speed00001
Thanks for your replies.As i am breaking the car i will remove it anyway and check it out.
I will post back when it is off,to answer the question conclusively.
Cheers guys from your answers it is worth taking it off.
Old Feb 5, 2011 | 06:50 AM
dojj's Avatar
dojj
The Granada beams and sierra beams for the dohc engines all used the 7.5 inch diff with the 3.92:1 ratio so should all fit without an issue, but ford are notorious for swapping bits over at whim so this my not be the case for evry single car, but it's been the case for evey single car I've stripped/worked on and that's plenty
Old Mar 15, 2011 | 08:35 PM
Austin101's Avatar
Austin101
Your talkin sh** now
Is the sierra 2.0 DOHC 8v back axle same as a cosworth apart from the diff and can you fit the cossy diff later on
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
