Removing Crankshaft Pulley
Old Jan 27, 2011 | 12:41 PM
Paul_Painter's Avatar
Paul_Painter
Default Removing Crankshaft Pulley
Hello Chaps
It will be time to change the cam belt on the Escort soon and I will of course need to remove the crankshaft pulley. Last time I borrowed a puller but I can't get hold of the tool this time.
I have been told that there are 2 types of bottom pulley, 1 with 3 screw holes and 1 without. Mine has the screw holes and the last puller I used was specifically designed for these holes and made the job very easy!
How does everyone else remove the pulley? Is there a commercially available tool?
Any advice or guidance would be appreciated.
Paul
Old Jan 27, 2011 | 05:25 PM
Steve Escos's Avatar
Steve Escos
I bought the tool from ebay. Sold the escort so if you want it £25 delivered
Old Jan 27, 2011 | 07:01 PM
A lot easier with the tool, but once off lap the pulley and crank nose with some valve grinding paste, after removing woodruff key, till it's a snug rather than stupid tight fit, takes about 30-45 mins but well worth doing, as can then be slid off with 1 finger, bolt only needs tightening to normal torque, no thread lock needed.
Old Jan 27, 2011 | 07:15 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
dont hit it with a hammer like i did
Old Jan 27, 2011 | 07:18 PM
lawnsy's Avatar
lawnsy
I use one of these...
http://www.machinemart.co.uk/shop/pr...balance-puller
Old Jan 27, 2011 | 07:19 PM
lawnsy's Avatar
lawnsy
Fit perfect on the 3 bolt pulley's....
Old Feb 1, 2011 | 12:35 PM
Paul_Painter
Hello Chaps
Thanks for the comments and advice, I just ordered the puller from MachineMart as recommended.
Much Appreciated.
Regards
Paul
Old Nov 3, 2011 | 06:11 PM
xenton's Avatar
xenton
Enthusiastic Novice
Originally Posted by lawnsy
Hi,
I know this thread is a few months old now but I'm having trouble getting my crankshaft pulley off and came across this thread. I've got a 2000 (W) 1.6 escort and the crankshaft pulley has 3 holes in, but they aren't threaded, so how can that puller work, am I missing something?
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Orion_Gav
Sep 29, 2015 04:50 PM
