What wires?
Old Jan 27, 2011 | 11:20 AM
BIL N KEL's Avatar
BIL N KEL
Default What wires?
What colour wires which come from the stalk are for the windscreen washers?
Thanks Billy
Old Jan 27, 2011 | 01:59 PM
jon@work's Avatar
jon@work
Fuse 15 feeds 12V to stalk terminal 54 (black/violet wire). When the washer button is pushed, a connection is made within the stalk, joining terminals 54 and 53C (black wire). 12V is thus fed to the pump. Instead of the second pump terminal being directly connected to earth, the wire from the pump (black/yellow wire) returns to the stalk (terminal W), where there is a permanent connection to stalk terminal 31, which should be earthed (brown wire).
Old Jan 27, 2011 | 03:13 PM
Bloody hell Jon you know your stuff.
Old Jan 27, 2011 | 06:32 PM
BIL N KEL's Avatar
BIL N KEL
cheers mate
Old Jan 28, 2011 | 03:30 PM
BRAMMER's Avatar
BRAMMER
Jon i have been having a few issues with my washer - when it was tested they said it had 2 live wires is this right on a 3dr? tried to find a wiring diagram online but failed - any advice
Old Jan 28, 2011 | 04:15 PM
martysmartie's Avatar
martysmartie
I think it's just the one live to the pump as said, although I think you have two pumps on 3DR, one for the rear as well.
Martin
Old Jan 28, 2011 | 05:00 PM
jon@work's Avatar
jon@work
The terminals on 3dr stalks, IIRC, are laid out differently to later sierra stalks. Is it definitely an original 3dr stalk you've got fitted ? If not, this could well be the cause of your problems.
The 3dr washer pump should take a feed directly from fuse 4, and then on to the stalk (black wire terminal 53C), which switches to earth when the washer button is depressed (via brown wire terminal 31).
Old Jan 28, 2011 | 06:11 PM
BRAMMER's Avatar
BRAMMER
Cheers for the info i will investigate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
