Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
mk1 fiesta suspension
Old Jan 26, 2011 | 06:28 PM
PileOfRust's Avatar
PileOfRust
Default mk1 fiesta suspension
hello
im currentley restoring a 950cc povvy spec mk1 fiesta for my first car, and i need help deciding on what parts to get for the supension.
i want the car lowered 40mm but i want the handling improved at the same time. i think ive decided against coilovers because of the price of them so they can wait until i change the engine.
im going to get polybushes all round (firm up the ride slightley and last longer) and an adjustable xr2 panhard rod but i dont know what shocks and springs to get. People have recommended mk2 xr2 shocks all round with 40mm lowering springs but i dont see why you should use mk2 shocks (anyone explain why? )
The car will more than likely be driven all the time so i dont want suspension thats completley rock solid, but i dont want the car wallowing around neither.
what shocks and springs shall i look for and what sort of money are they?
ive looked on demontweeks and fiestacentre but they dont seem to have much for them
any idea appreciated cheers
Old Jan 26, 2011 | 07:29 PM
James's Avatar
James
don't fit mk2 shocks on the front as i think they give too much negative camber as the mk2 has a wider front track.
in my opinion i'd be looking towards koni or g-max set of springs and shocks. and fit a rear anti-roll bar & good quality tyres. Poly bushes make a huge difference and well worth doing.
hope this helps.
Old Jan 26, 2011 | 07:33 PM
PileOfRust's Avatar
PileOfRust
hope this helps.
thanks for that
where can i get a full set of koni or g-max springs and shocks? just ebay or any other dealers?
cheers
Old Jan 26, 2011 | 08:29 PM
James's Avatar
James
not a clue i'm afraid!
burton power?
Old Jan 26, 2011 | 08:37 PM
PileOfRust's Avatar
PileOfRust
way too expensive
Old Jan 26, 2011 | 09:11 PM
jammerrs's Avatar
jammerrs
id go for spax or koni personally , or wait till you can afford coilovers and just do it once?
Old Jan 26, 2011 | 09:16 PM
PileOfRust's Avatar
PileOfRust
yeah that would be the best bet i guess.
now i know what i want for me birthday...
400quids worth of suspension
do they go straight onto the car without any modification?
Old Jan 26, 2011 | 09:18 PM
bythomson's Avatar
bythomson
are you on the mk1 fiesta website, loads of really good build threads
tbh poly bushes and a decent set of springs and new shocks will be stiff enough, if its the original engine you wont need over the top suspension. just stiff enough but still comfortable
save money on coilovers and maybe buy an anti roll bar kit or bigger tie bars etc
Old Jan 26, 2011 | 09:38 PM
James's Avatar
James
tbh i preferred the handling of my mk1 before i fitted coilovers. infact for a road car/daily driver that was probably the worst mod i ever did!
Old Jan 26, 2011 | 10:04 PM
PileOfRust's Avatar
PileOfRust
okay cheers
i'll try and source a set of koni's or spax's all round with lowering springs
Old Jan 26, 2011 | 10:26 PM
Rax's Avatar
Rax
My mate may have a mk1 fez koni set up left over from when he stripped his.I need to check this plus I put mondeomark in contact with him and he says he wants all the parts available.I will try and find out tomorrow.
Old Jan 27, 2011 | 06:31 PM
PileOfRust's Avatar
PileOfRust
cheers mate, although i prob wont have the money for it if its still available
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
L1AM_RS
Sep 23, 2015 03:27 PM
PeterLucas
Sep 21, 2015 11:36 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Ben26
Sep 3, 2015 07:55 PM
