Need rear disc whats possible!!!
my mates got the rs2000 set up and i didnt even notice cause it has this back plate behind the disc so its not very noticable and ive seen cars with the brackets and they do look better but i think they are more work to get fitted! id go for bracket even though its a bit more expensive
With the fiesta centre kit you will need to buy the calipers and a brake bais valve seprately.I have there kit and now i wish i hadnt bought it as i think i could have made it myself apart from the bracket's.If i remember right the rear hub you get in the kit is just a fiesta mk2 or 3 front hub that just goes onto the stub axle.I will get some pictures soon of mine as i am gonna be stripping them down.Might find out if someone will make sum brackets up using mine as a pattern.
Brian
Brian
thnaks for the info the ad you see in mags seems to show everything you would need, wont bother with it now get some pics up would be intresting to see what you do get as i am to looking to do a rear disc converstaion.
i got the fiesta center rear set up, havent fitted it yet, i have got a bias valve but im gunna fit 1 to each line to stay in with the normal system.
as for calipers, there just seirra/granda rear calipers, £5-10 each from scrappy.
the hubs are not mk2 or 3 fiesta front ones, as the front hubs have the lug's to mount the calipers on.
i do know what are used but im keeping that close to my cheast for now as i plan to make up some kits to sell
just waiting to get my lathe so i can make the spacers for the hand brake cable.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
155lee
Sep 6, 2016 11:10 AM
