whats the correct way to set.....
whats the correct way to set a 4x4 tps?
i measyre votage at the ecy connector between pin 17 and earth, 0.6volts at o% and 4.6volts at fullt throttle! am i right in doing this?
for some reason im douting myself
PassionFords Creator
0.2 - 0.25volts at idle is the important part Gareth.
0.6 is well documented but has been found to be out of tolerance with some ecu's and the 0.2 figure suits all.
Can you not set it the same way you do the 24v lump, disconnect ISCV and set for a certain number of revs at idle (it's 775-825 on the EEC-IV 24v V6)
Much easier than mucking about with multimeter and wrecking your multiplugs
i car dont like 0.6 thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
