water pump
Old Jan 22, 2011 | 09:07 PM
bruny's Avatar
bruny
Default water pump
alright guys .getting my timing belt changed soon and was just wondering is it worth wile changing the water pump on while the timing belt is off,
also been looking on flebay for water pumps and comes up with alot of 2wd pumps,my car is a 2wd with a 200 block,so would i need a 4wd pump or could i use a 2wd genuin one.
thankyou lads
Old Jan 22, 2011 | 09:17 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
the things i look at when changing a waterpump when the belt is off is how old is the pump?? what condision does it look/feal in?? how many miles has it done?? and does the price of a new one warrent taking the belt off in 6 mounths when its leaking?? imo change it for pice of mined if the price is not to bad..
im not to sure on the water pumps but im 99% sure they are the same
Old Jan 22, 2011 | 10:02 PM
jamie's's Avatar
jamie's
cossy water pumps run off the fan belt not cam belt
they can be changed without taking off the cam belt so can be done at any time
the 4x4 and 2wd water pumps are completely differant
look at your thermostat housing,
if its got 1 pipe you need a 2wd waterpump
if its got 2 pipes you need a 4x4 waterpump
Old Jan 23, 2011 | 08:05 AM
bruny's Avatar
bruny
thanks lads for the replies.for the price i may es well replace it to put my mind at rest
Old Jan 23, 2011 | 03:02 PM
cosy trav's Avatar
cosy trav
Sure the water pump off a pinto engine is the same as 2wd cosworth and about half the price .
Old Jan 23, 2011 | 03:11 PM
clarke5700's Avatar
clarke5700
i stand corrected
Old Jan 23, 2011 | 03:30 PM
The easy external way to tell apart is the location of the alternator bracket lug/feed pipe.
The pumps can be used in each others blocks, the 4wd pump has MUCH more flow capacity.
The stat housing means nothing as regards the water pump as there can be a mix of 2wd and 4wd head/blocks.
Personally if it was ok I would leave it, even new ones can fail, what's worse a old working one or a new unknown one ?, as said very easy to change without disturbing belt anyway.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
