Standard 2wd Motorcraft clutch
Old Jan 22, 2011 | 07:42 PM
rs2klee's Avatar
rs2klee
K***LMT
Default Standard 2wd Motorcraft clutch
hi all, anyone know if anyone stocks the standard 2wd motorcraft clutch kit, tried my local ford dealer and none in stock
cheeRS all...
Old Jan 22, 2011 | 07:51 PM
botters's Avatar
botters
competant bodger
i got mine from woodford garage on ebay
Old Jan 23, 2011 | 02:06 PM
PAUL S's Avatar
PAUL S
The ford ones are made by LUK rather than AP these days so you are better off just buying direct from an aftermarket company rather than through Ford and paying a premium
Old Jan 23, 2011 | 03:34 PM
As said wooforde have these on the shelf.
Old Jan 23, 2011 | 05:08 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Have LUK on the shelf.......as mentioned LUK make them for Ford
Old Jan 23, 2011 | 09:46 PM
rs2klee's Avatar
rs2klee
K***LMT
hmm thanks for the info.. i did see them LUK ones, my car has the so called stage 2-3 with greens and 3bar and MSD chip, its not a race car just used for the road.
Matt bought a few things from you before would you think the LUK one would be ok for my setup ?
Old Jan 23, 2011 | 11:19 PM
botters's Avatar
botters
competant bodger
i run standard on stage 3 with no problems, i dont launch the car too often tho
Old Jan 24, 2011 | 04:58 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
the last clutch a got for mine was from the local motor factors was just a LUK one and dus the job just fine as a everyday driver
James Porter
Oct 28, 2015 12:17 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Old ford
Jul 31, 2015 06:50 AM
