ford focus fault code P0420
Old Jan 21, 2011 | 05:48 PM
kingcol's Avatar
kingcol
Default ford focus fault code P0420
catalyst system low efficiency what do i need to do to repaire this problem all help welcome
Old Jan 21, 2011 | 05:57 PM
RichieST's Avatar
RichieST
ST170 by any chance?
It's the pre cat lambda sensor that needs changing.
Old Jan 22, 2011 | 05:19 PM
gingeRS's Avatar
gingeRS
if its an rs running a decat then this can cause that fault.....just have to clear it every now and again
Old Jan 22, 2011 | 05:55 PM
phil_focus's Avatar
phil_focus
that codes saying it thinks the cat is fucked.
do you have a cat? with a cheater?
could also be the post cat sensor faulty.
Old Jan 22, 2011 | 06:18 PM
phatfordxr4i's Avatar
phatfordxr4i
is the code cat effinency below threshold if so more than likely cat you need to ckeck the lamba s if they are switching the same your cat up the swaney
nick8saff
Aug 16, 2015 05:35 PM
taylora1409
Aug 12, 2015 12:06 PM
