Water pump change on 2002 transit-- any help
Old Jan 19, 2011 | 12:45 PM
TIFF's Avatar
TIFF
Chasing Radders
Default Water pump change on 2002 transit-- any help
I think the Water pump on my transit is knackered as the thing keeps getting mega hot then dropping back to normal, heater goes hot then cold and the top hose is red hot but the bottom one is cold off the rad.
I have flushed the system through and bleed it for airlocks but no different...
How hard is the water pump to change and how????...... Many thanks
Old Jan 19, 2011 | 02:34 PM
TIFF's Avatar
TIFF
Chasing Radders
Anyone?????
Old Jan 19, 2011 | 02:44 PM
Danwood79's Avatar
Danwood79
There is a water pump for the 2.0 diesel that is 4 bolt on to the engine,
the water pump for the 2.4 diesel is a remote pump not directly connected to the engine.
Don't know how hard they are to change as we only supply parts.
Old Jan 19, 2011 | 03:19 PM
reisskahn's Avatar
reisskahn
Tiff we've got the same problem on a galaxy tdi fricken temp goes to hot then back to normal but only whilst its underload.
Seems tl lose a tad of water aswell but don't know where its loosing it from
Worst thing is waterpump was changed priorto this aswell
Wondering if anyone can help out here?
Old Jan 19, 2011 | 07:00 PM
little bram's Avatar
little bram
RWD (2.4) is easy mate the FWD arent hard just alittle harder to get it to.
If it FWD when you get it off check the pas pump it runs the water pump and most of the time it them thats the problem.
Old Jan 19, 2011 | 07:07 PM
They arnt that bad to do.There are a few pipes in the way.Like said the Pas pump is bolted to it and sometimes the shaft can wear that drives the water pump.
Old Jan 20, 2011 | 02:29 PM
TIFF's Avatar
TIFF
Chasing Radders
All sorted.......was abit of a pig to get to, had to remove the starter motor ect......but the water pump was the issue....all sorted now...
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
