Mondeo Headlights etc
Looking at getting a ST24 very soon, maybe have one at the weekend/next week all being well.
I want to do the black effect on the standard headlights, is this easy to do? Do they come apart easy? ie clipped or glued? I had some rover ones i did they were glued and had to use a heat gun to get them apart and yeh they looked good done but always steamed up? Just wondered how easy they were to do ?
Also whats that black plastic splitter i see on the bottom of a lot of ST24s? Is it the seat leon cupra one?
Finally, whats the best lowering springs for an ST24? and what drop? 30 - 40mm ? obviously dont want to smash the bumpers
Thanks
Thanks
The lights come aprt if you place them in a warm oven for a couple of minute or use a heat gun to sotfen the glue.
The splitter is indeed a Cupra R but they are now getting so common I am thinking of taking it off mine.
I have droppe dmy 200 estate by 40mm all round and it can not be parked by akerb as it will catch every time so I would go for a set of PI 30mm springs.
its finding a set thats the problem. new sets are like hens teeth, and second hand sets are few and far between, then you got the price issue. average second hand sets go for between £150 - £200, and a lot of the time, the lenses need replacing as there prone to rusting, and genuine lenses are about £70 per lens, and there are 4. you can get around that problem, and buy cheap halfords lenses at £22 for 2, but they look awful.
if your not confident about doing the black eyes yourself, you could buy a set thats already been done. there are plenty about, and a set can be had for as little as £40, then you got your standard lights as spares.
as for lowering, mine's -35mm all round, the front isnt to bad, but i cant reverse into spaces with reasonable size kirbs, because my rear bumper catches, and unless i crawl over speed bumps, at a certain angle, my exhaust catches on them.
You dont have to paint them? I thought theyd be grey under the chrome? the rover ones were wen i flatted them back? i just masked off the inner cone and sprayed the rest. passed MOT fine. Id LOVE a set of morettes but theres none on ebay and there like £350 a set new
fiddy theres somewhere i found through google that does them £350 a set but theyre made to order. genuine morettes. yh my suspension was so shagged on my 1.8 lx that when i reversed into a space and then drove out again i ripped the rear bumper off!
that was a standard car, standard suspension, on 14 inch steelies
lol
lol
lol
lolas for lowering, pay a garage to do it, it will snap at least one hub bolt, and unless you have the rite drill and bits, drilling the fucker out will be a nightmare. i genuinely wouldnt recommend anyone lower a MK2 mondeo, unless you have a ramp, air tools, and heat. i know a guy who had his own garage, so had all the gear, did a lot of work on cars off the mondeo forums, and had an ST24 himself. he said on average, with all the rite tools, you were looking at a good three to four hours to change the springs, because 99.9% of the time, the pinch bolts snap. so he started heat them up before removing them, as when he didnt, they would snap, and he would spend most of his time drilling the fuckers out.
im sure glenn who posted above, will be along to tell you the fun of lowering mine. 7 hours, two burnt out drills, loads of snapped drill bits, cuts, bruises, and a lot of swearing
morrettes are hard to find, im still waiting for a set to go on ebay to see if its worth selling mine as im tired of them but im not going to let them go for little money lol
you can buy them new again £350 though
black eyes is the cheapest mod but only looks good on certain colour cars i think
If you are lowering it make sure you do the front 10mm more than the rear. The front arches are much larger than the rear so you need the extra drop to get the wheel to arch gap the same. I did my ST24 40mm all round and I was never 100% happy how it looked..
I think you can buy 40/50 kits but it's a while since I was looking..
but, as said, it does look the part, sits perfect
i spend a lot of time money in that petrol station. when i was in there today, i asked the lass behind the counter if there is any chance they can install tv monitors in the pumps, and play porn, so when im filling up, i can watch someone else getting fucked, while i am
wowk
Mar 30, 2021 07:49 PM
Steve Escos
Oct 1, 2015 06:57 AM
The Enigma
Sep 29, 2015 10:31 AM
