General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
New here.....flickering dash lights !!
Hi all,
i've recently bought a 52 plate 2003 focus st170 ( pics to follow ) and i love it......problem is, the dash lights have started flickering and two days ago the o/s main beam h/l blew.....this morning the n/s headlight blew....i had to drive to work with side lights and fog lights on !!....apart from this the car is fantastic....i know you have prob had this one before but any ideas or pointers to other discussions would be a great help.....regards Damo.
(oomigooly)
Occasional flickering does happen if you have got the bulb brightness set to max. Try turning it down a bit. Bulbs blowing just sounds like a coincidence!
thanks for your replies....i'll try the dimmer switch....will have to try the others at weekend....when its light.....hopefully the lights blowing IS just coincidence..
Mine did this too, you can as stated turn them down a touch. Its not uncommon for two h/l bulbs to go in close succession especially if they were put in as a pair.
