How to test amal valve?
Old Feb 1, 2005 | 11:54 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default How to test amal valve?
Alriiiight as title sais how do i test my erst amal valve? would this cause it to boost more than it should std if it was broke? i know it clicks with ignition, how else to test?
Old Feb 2, 2005 | 08:43 AM
Dave McB's Avatar
Dave McB
if u overboost by hoooooge amounts, check that the pipes are in properly to and from turbo
If it clicks with ignition it means that it is working......could be prob with another part.
only other suggestion is to try another one and c if tha does the same
Old Feb 2, 2005 | 08:46 AM
EssexBoyRacer's Avatar
EssexBoyRacer
An amal valve can click on and off fine with ignition but not hold boost pressure. The only way I can think of testing is to get one u know works and swap the jets.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
