Focus rs mk1 engine ticking
Old Jan 16, 2011 | 07:50 PM
Rodders24's Avatar
Rodders24
Default Focus rs mk1 engine ticking
Hi all
Just Wondered if any one can help? When I start my focus rs mk1 up from cold It sounds a little ticky. Once warmed up it go's a lot quieter but can slightly still here a tick if I rev/ accelerate.
I thought I could either be a sticky tapet or injectors?
Would any one recommend running an engine flush through it and may be some injector cleaner?
Any help would b great!
Thanks ash
Old Jan 17, 2011 | 11:54 AM
dieseldog's Avatar
dieseldog
it has been mentioned before to avoid engine flush as this could spell disaster for a standard engine let alone a performance one.
i dont know about rs engines, but i had a similar issue with a 2.6 audi coupe. it was terrible after an overnight rest, i thought the cams were about to bounce out, but i got told as they were hydraulic followers they drain of oil and the first couple of seconds was before they filled up again. i was using semi synthetic oil and swapped over to fully synthetic and it seemed ok. im not advising, just what i found personally.
Old Jan 17, 2011 | 12:24 PM
martysmartie's Avatar
martysmartie
I am pretty sure the RS would have solid lifters, however they may need adjustment but if so I should think they would be noisy all the time, again not saying this is it as I know nothing about these engines and there common flaws etc but just saying possible suggestions from what your saying, I am sure someone who knows better will be along soon...
Just had another thought I know the charge coolers on these can be problematic is that possible?
Martin
Old Jan 17, 2011 | 07:30 PM
DanFRS's Avatar
DanFRS
worn shims
Old Jan 19, 2011 | 04:41 PM
Rodders24's Avatar
Rodders24
Worn shims? What's involved in sorting that out?
Ash
Old Jan 20, 2011 | 08:56 AM
martysmartie
His saying what I was that the tappets need adjustment, do a search on here as there a bit of mathematics involved, it basically involves replacing the metal shims on the tappets to give the correct valve clearances.
Martin
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
