bfrake lights stay on fiesta 3.5
Old Jan 16, 2011 | 04:57 PM
a1i.c's Avatar
a1i.c
Default bfrake lights stay on fiesta 3.5
I've been a very busy bee and worked on my car for 10 hours this weekend (see post https://passionford.com/forum/restor...er-things.html about what needs done).
However there's been an issue arise - my brake lights stay on all the time, unless I push the brake pedal up. I'm assuming there tension needs adjusting on either the pedal or the switch - which one would be advisable? Ive taken the switch out and put in my Mk3 switch (from the donor car) and it's a different size and is continually pressing on the brake pedal and therefore the brakes are engaged.
Any advise would be great.
Old Jan 16, 2011 | 05:04 PM
Brendan's Avatar
Brendan
struggling with reality
I would get a replacement switch from a scrappers near you cost you 1 or 2 quid. easy job to put in and check! if you dont have a scrapper near you message me and I'll see what I can do!
Old Jan 16, 2011 | 05:06 PM
Fiddy's Avatar
Fiddy
yeah, id change/adjust the switch
Old Jan 16, 2011 | 05:11 PM
Dal_'s Avatar
Dal_
Your brake light constantly on could be your brake fluid is low in the reservoir as there's a sensor on the lid I think. The is on the Mk4/5 anyway.
Old Jan 16, 2011 | 06:05 PM
Paul_RS's Avatar
Paul_RS
Not just adjust the switch down a bit to meet the pedal? :S
Old Jan 16, 2011 | 06:12 PM
Oranoco's Avatar
Oranoco
Switch is adjustable??
Old Jan 16, 2011 | 06:23 PM
Brendan's Avatar
Brendan
on my mk3 when you turn the ignition on the brake warning light goes on un plug the sensor on the brake fluid resovoir and it goes out.....
I can't start the engine to check what happens when the engine is running at the moment as I am half way through changing the engine mounts... and the new titainium nuts haven't arrived
Old Jan 16, 2011 | 07:02 PM
martysmartie's Avatar
martysmartie
Assuming the level is correct, I suspect there is a problem with the sensor?
Martin
Old Jan 18, 2011 | 06:31 PM
Brendan's Avatar
Brendan
found this in EBAY for you item no:230573804603
MK1 Ford Fiesta/Escort RS Turbo XR3i Brake Stop Light Switch
brand new Brake Pedal Stop Light Switch Assembly suitable for the following models:
MK3 MK4 Ford Escort from 08/1980 to 08/1990
MK1 Ford Fiesta from 05/1976 to 08/1981
Old Jan 18, 2011 | 07:20 PM
a1i.c's Avatar
a1i.c
Turns out that the switch is adjustable - it has ridges on the side which allows the switch to be held in place and moved. So all I had to do in the end was move the switch one knotch and the brakes now work!
I had planed to put a rubber mount on the brake pedal (one from the bottom of a computer, or laptop) but didn't need to!
hopper350
Sep 4, 2015 12:53 AM
Ben26
Sep 3, 2015 07:55 PM
turbowag
Sep 3, 2015 08:07 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
