wht coilovers?
Old Jan 16, 2011 | 04:04 PM
155lee's Avatar
155lee
Default wht coilovers?
i want a set of coilovers for my 2wd sierra saph,i dont want the £500 gaz suspension,i had avo a few years back and liked them,where could i get leda coilovers from?
the car is a road car,stage 3.
also is it necessary to upgrade to heavier lb springs with the cheaper kits?
Old Jan 16, 2011 | 04:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Gaz golds with the correct poundage on mine,find them better than the konis with bayjoo springs I had on before.
Old Jan 16, 2011 | 04:08 PM
JOEYRWD's Avatar
JOEYRWD
also gaz
STUCOS's Avatar
STUCOS
Lee why not just fit koni,s and ahmed springs,seen as you arnt going to buy dear coilovers,my money would be on a set of bad's from mike r ,any way,thought you wernt spending much on this saff
cheeRS stu
Old Jan 16, 2011 | 04:22 PM
155lee's Avatar
155lee
i have konis already but i want it to sit right,the experiance i have had with springs in the past has always left me dissapointed with the height,least with coilovers i can adjust to whatever height and get it corner weighted,as for spending money on it,you know what like !
where do you get the correct lb springs and are the gaz golds around £8-900?
ill call you back in a min stu,just getting ready for work the now!
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
