2wd Gearbox question (Cossie)
Old Jan 15, 2011 | 04:56 PM
Kelv's Avatar
Kelv
Almost there!
Default 2wd Gearbox question (Cossie)
well,
i bought a 2wd gearbox a little while back on the basis that it had a suspect 3rd gear issue as it had locked/jammed in 3rd.
anyhow, i was fiddling about with the gear selector and it sounded a bit clonky with no attempt at it actually trying to dissengage gear, so i removed the selector cover and found the big nylon bush had worn to excess and allowed the bottom of the gearstick to pop out of its location.
with it all exposed, it engages every gear perfectly when doing so by hand, proving it was just the issue where it had dislodged itself and the gearstick not actually doing anything.
i put the selector back together without the worn bush and you can now fully engage every gear from the gear stick, just a bit sloppy as it takes up the play where the bush used to be.
My question: can the following bush be purchased anywhere, or does anyone have one available.
if i can replace this item then i can sell it as a fully working box again
cheers
Kelvin.
poor pictures as i did it in failing light.
Old Jan 15, 2011 | 05:36 PM
gibbo frst's Avatar
gibbo frst
theirs a guy on ebay doing recon t5 boxes called gears and he does metal bushes and my box came with one and have to say it is better than the plastic one .. think they are ten quid but im sure he would have the plastic also.. if you cant find him on their his number is
07850797026.. unless its changed since..
Old Jan 15, 2011 | 05:40 PM
Kelv's Avatar
Kelv
Almost there!
thank you very much, thats brilliant
James Porter
Oct 28, 2015 12:17 PM
Oct 9, 2015 07:38 PM
Chas
Sep 21, 2015 08:57 PM
FlashRS
13
Aug 31, 2015 06:02 PM
RsS2daz
Aug 14, 2015 05:26 AM
