Weird engine noise- help
Old Jan 15, 2011 | 04:05 PM
Craigorypeck's Avatar
Craigorypeck
Default Weird engine noise- help
My NA YB has a weird whirring noise at the front. Sounds like its near the aux shaft.
Rebuilt very recently and I thought the cam bearings were the cause so I changed them. Noise is still there. It's only there when the engine is idling, twiddle the throttle and it goes away, creeps back in as engine revs die down. Can anyone suggest what it may be??
Old Jan 15, 2011 | 04:08 PM
Turbosimpsons's Avatar
Turbosimpsons
belt to tight.
Old Jan 15, 2011 | 04:15 PM
Craigorypeck
thats what I thought initially so its set to be turnable 90 degrees...
Old Jan 15, 2011 | 07:37 PM
Craigorypeck
After all the dicking about I've stripped the threads outta the head for the belt tensioner. Shite. Helicoil time.
Old Jan 15, 2011 | 08:34 PM
Turbosimpsons
make sure you drill it straight.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
muz
Aug 1, 2015 06:48 AM
