How to remove the windscreen?
Old Jan 14, 2011 | 10:28 AM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Default How to remove the windscreen?
Hello,
So i need to take my windscreen out of the saph.
It has been put in with something like silicone i think, should i just get a knife and cut round this then push it out?
When it is out do i clean all the silicone off for when it goes back?
Any help would be brilliant thanks!
Many Thanks Eigdoog.
Old Jan 14, 2011 | 10:29 AM
R4N SS's Avatar
R4N SS
hammer
Old Jan 14, 2011 | 10:36 AM
Char1ie's Avatar
Char1ie
Pull the rubber seal out from one end all the way round.
Then buy a windscreen cutting wire. Feed the end of the wire through at the bottom corner. With one person in and one person out you can then effect a swing cheese cutter motion and use the wire to cut all the way round. Then the screen will lift off. Easy job. Did it recently.
Charlie
Old Jan 14, 2011 | 10:37 AM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
lol, i did think that but didnt want to get glass everywhere.
Old Jan 14, 2011 | 10:38 AM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Charlie
Cheers!
Ima give it ago!
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
