Block Heater
Old Jan 13, 2011 | 03:11 AM
J_Train's Avatar
J_Train
Default Block Heater
How many of you guys use em? and if its going to get really cold out do you plug em in and leave em on all night?
Old Jan 16, 2011 | 10:55 AM
I've never known a single person in the uk use them, doesn't get that cold here, only about -15C on a really bad winter.
Old Jan 17, 2011 | 11:49 PM
J_Train's Avatar
J_Train
well thats what i told the guy... i have never used mine at my house in Georgia here in the states.... and it gets -10F about -23C on very rare occasions. my main residence is in Florida and thats where the guy im asking for lives... i told he didn't need to use it. Thanks for the info
Old Jan 18, 2011 | 06:04 PM
I have a friend who work sin the Kamchatka region in Siberia, where's it's routinely -50C and more, they don't use block heaters either, they simply don't turn them off if outside, as they won't restart, or keep in a centrally heated garage, with a block warmer as well!!
Old Jan 18, 2011 | 06:14 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
U can get a night heater on dafs than pumps the coolant round the engine via a pump in the night heater so the cab is warmed via the normal heating vents in the dash unlike a normal night heater that sits behind the drivers seat.So when its running it also keeps the engine warm but they are very rare i have only ever seen one on a top spec xf 105 that drives abroad alot there made by eberspacher
Old Jan 22, 2011 | 08:47 PM
Colin_P's Avatar
Colin_P
Believe it or not I've got one fitted to my MK1 Focus TDDI and it is brilliant. A Kenlowe hotstart. It is a 3kw unit and will heat the engine in about 30-40 mins. Not need to keep it on all night, just use a timer plug.
Instant heat from the heater as well as the fuel savings on cold starts. Have been a real bonus this winter. Quite pricy but I'm looking at keeping it a long time and transfering it from car to car. Should have bought one years ago.
Below are some piccies when I fitted it...
Old Jan 23, 2011 | 08:03 AM
FRS#3425's Avatar
FRS#3425
I have a block heater installed in my FRS. Works really well...
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
