2wd sapphire with 4x4 header tank
Old Jan 11, 2011 | 12:54 AM
cossiedad's Avatar
cossiedad
Default 2wd sapphire with 4x4 header tank
As per title, why is this done? (there must be a reason as a silicon adaptor hose is sold by Roose Motorsport?)
I had this set up on my old cossie and I'm rebuilding my new one with most of the parts from the old one. I also have a swirl pot in the system and I'm trying to work out where the hoses go! (I stripped the old one about 5 yrs ago and my memory is not that great lol). My header tank is a polished one so I want to use it really.
My new engine has a 4wd head on it - will this make any difference to this set up?
cheeRS
Old Jan 11, 2011 | 06:46 AM
AJC's Avatar
AJC
No. You will be fine. It's the hose kit that's different I think
Old Jan 11, 2011 | 07:52 AM
Fezman1's Avatar
Fezman1
It is done because you can still buy brand new std 4x4 cos header tanks and they are relatively cheap.
std brand new 2wd header tanks - think they are like rocking horse doodoo.
Old Jan 11, 2011 | 09:44 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
That is correct!!
Old Jan 11, 2011 | 10:25 AM
I used a 4wd one because they don't do the 2wd one, and I'd rather be able to see the level easily.
Old Jan 11, 2011 | 10:37 AM
neilscott83's Avatar
neilscott83
I want a standard 2wd header tank pisses me right off not having the original on mine!
mint_s2
Sep 2, 2015 08:58 AM
AndrewStrang
Sep 1, 2015 11:16 AM
FlashRS
13
Aug 31, 2015 06:02 PM
155lee
Aug 14, 2015 11:21 AM
Old ford
Jul 31, 2015 06:50 AM
