Water Injection
as above,is it worth it.On a hot day,my temps may go up to 50-55.if i'm really pushing it.I,m running about 330bhp.I'm assuming that when the temp goes up it retards the ignition.At what temp does it start to retard if this is the case.Where is the best place to install the injector.I was thinking of a basic system that works on temp and boost level.
thanks matt
thanks matt
Snow performance for me,its triggered from the ecu(swift light) or u buy the kit that has the map sensor and starting to spray in certain revs.i have it as a dual set up on my inlet,ambient or about 40celcium,
Mark RS
Oct 12, 2015 06:01 AM
