zetec turbo no boost
Old Jan 9, 2011 | 01:05 PM
escortzetecturbo's Avatar
escortzetecturbo
Default zetec turbo no boost
i have built a 2.0 zetec turbo, using decomp plate, inlet adapter to use frs turbo inlet and ecu, and zetec flange welded onto erst t3 manifold with t3 turbo, front mount intercooler and universall pipe kit off ebay, but it will only boost to like 1-2psi and just feels like a diesel to drive, thats even with the pipe removed off the actuator, intercooler has no leaks and nor does the piping had it pressure tested, any ideas why its not boosting? also wont tick over and runs really rough and miss fires under half throttle, do you think it could have a air leek between the adapter plates on the inlet manifold and thats where its loosing all the boost and thats whats making it run rough?
Old Jan 9, 2011 | 02:40 PM
JonathanJ's Avatar
JonathanJ
One thing I have done in the past is to remove a inlet pipe and run it like a N/A and then rev it with your hand over the intercooler outlet and see what pressure you get there , if you have pressure then it is getting that far , it could be a leak and that is what is causing the misfire , sometimes difficult to find , another trick is to start it in a sealed state and spray some brake cleaner towards your suspected leak area , only a quick squirt though , it will get sucked in and will burn like petrol and it will rev , so be careful how much you use .
Old Jan 9, 2011 | 03:17 PM
dexterford's Avatar
dexterford
fghfghf
Old Jan 9, 2011 | 03:37 PM
escortzetecturbo
ok will get tome break cleaner tomorrow and give that a try, took the pipe off the intercoler and when revved loads off air is coming out so its getting that far, and its only a t3 turbo so will be fine on the 2litre
Old Jan 10, 2011 | 03:42 AM
dexterford's Avatar
dexterford
ghjghjgh
Old Jan 10, 2011 | 03:38 PM
Sp3no's Avatar
Sp3no
Surely on a boosted engine there is no vacum so if you spray brake cleaner where you suspect a leak it will be blown out by the leaking boost rather than get sucked in?
Old Jan 10, 2011 | 03:55 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
What preload do you have on the actuator?
Old Jan 10, 2011 | 06:36 PM
JonathanJ's Avatar
JonathanJ
There will be vacuum when throttle is shut from the throttle plate to the valves , boost only comes in at higher revs .
Old Jan 10, 2011 | 09:19 PM
escortzetecturbo
Well took the inlet manifold adapter plates off today, put a bit of instant gasket on the gaskets ticks over a lot better now and is boosting to around 5-6psi a lot quicker than before but that is still with the actuator pipe off and it wound all the way in, so do you think I need a new actuator? Will replace the inlet gaskets aswell, no leeks on the intercooler pressured them up to 25 psi and not one leak so all good there
Old Jan 10, 2011 | 09:20 PM
escortzetecturbo
And also feels really laggy gets to about 4000 rpm before starting to make boost
Old Jan 10, 2011 | 09:28 PM
mr_joe0606's Avatar
mr_joe0606
how was you controlling the boost
Old Jan 10, 2011 | 09:30 PM
escortzetecturbo
I have no boost controller only the pipe that goes to the pipe that goes from the actuator to turbo no amal valve
Old Jan 10, 2011 | 09:33 PM
mr_joe0606's Avatar
mr_joe0606
what management are you using ?
Old Jan 10, 2011 | 09:35 PM
escortzetecturbo
Fiesta rs turbo ofac ecu, beigh injectors and 195 chip
Old Jan 10, 2011 | 09:38 PM
mr_joe0606's Avatar
mr_joe0606
try winding the actuator back and puting a bleed vave in the pipe from actuator to turbo. and is the adaptor plate true and staight. get a stright edge on it. how was the maifold welded inlet and exhaust.
Old Jan 10, 2011 | 09:43 PM
escortzetecturbo
Okay will give that a try, want to get a new actuator though becaue if I blow air into it it leaks out instead off mooving the rod out so guess its no good haha, have not checked the inlet adapters but will be getting new gaskets for them because they are leaking, and I bought the exhaust manifold already welded
Old Jan 10, 2011 | 09:45 PM
mr_joe0606's Avatar
mr_joe0606
well check the exhaust manifold is stright as sometimes the welding warps them. and same with inlet.
Old Jan 10, 2011 | 09:47 PM
escortzetecturbo
Okay will do mate thanks, just want it running well enough to take it to dyno to get it set up properly o
Old Jan 10, 2011 | 09:56 PM
Big Will_'s Avatar
Big Will_
As I asked earlier - about preload...
It sounds like your actuator is indeed fucked. If the actuator isn't preloaded correctly and holding the internal wastegate penny shut it will behave exactly as you've described.
Old Jan 11, 2011 | 03:42 AM
dexterford's Avatar
dexterford
fgjhtgjghj
Chopshop85
Oct 31, 2015 06:15 PM
hog
Aug 16, 2013 02:04 PM
pope11787
Jul 27, 2010 10:57 AM
RScrew69
Jun 17, 2009 12:14 PM
Dragsteer
Jan 30, 2007 07:18 PM
