fuel filter replacement cost
Old Jan 7, 2011 | 07:14 AM
valkyrie's Avatar
valkyrie
Default fuel filter replacement cost
Hi. I am new here. I needed to replace my '05 focus ZX5 4cyl. fuel pump. Problem is I'm out of budget and ahop qouted me $360 for this. So i'm thinking of doing it myself. Any idea on how much it would cost me? and also what would be the tools that I'll be needing.
Old Jan 7, 2011 | 09:05 AM
chuckhumprey's Avatar
chuckhumprey
You will be needing a combination wrench set,multimeter and Socket & Ratchet Set. You can try to check it on auto repair estimate. It will probably cost you $150 if you do it yourself.
Old Jan 7, 2011 | 01:21 PM
dieseldog's Avatar
dieseldog
dont know about an 05 and american variants, but i changed the filter on my 2000 1.6 zetec and even though a little awkward it was a piece of cake and a hell of a lot cheaper than getting some grease monkey that will charge you Ł45(uk)an hour. you can get filters on ebay cheap, just get the rear of the car up on axle stands and find the filter by the fuel tank. the most awkward things to undo was the clips that hold the fuel lines, but once off its just a case of getting a socket with a long extension bar to get at the bracket that hold the filter to the body.
just remember to relieve the pressure in the lines by isolating the fuel pump(fuse out), then running the car until it runs out, but watch your eyes because there might still be a bit left when you split the hoses.
Old Jan 7, 2011 | 02:50 PM
Basic tools needed, piss easy job take about 1 hour max, cost of filter under 20 greenbacks.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
YODI
Aug 30, 2015 01:12 PM
3doorcozmess
Aug 21, 2015 11:17 AM
ekjim
Aug 17, 2015 08:57 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
