cooling problem st24
Old Jan 6, 2011 | 05:57 PM
charliekp's Avatar
charliekp
Default cooling problem st24
hi guys,need some help......my st24 runs ok but the expansion tank is cold even when the temperture gauge is in the middle,and the heater works fine...i dont understand why the water in the tank is cold when the car is hot?????? can anyone help me please
Old Jan 6, 2011 | 06:17 PM
botters's Avatar
botters
competant bodger
waterpumps are a common problem on these the blades break up and water stops pumping if left it will do the head gaskets look in the header tank while running and see if water is being returned to the tank
Old Jan 6, 2011 | 06:20 PM
Fiddy's Avatar
Fiddy
what year is it mate ?. the waterpump problems only occured on the MK1 V6, and early MK2.
Old Jan 6, 2011 | 06:28 PM
Chaz888's Avatar
Chaz888
same engine as mine dude check the thermostate next to water pump if this dose not open water will only move between engine and heater its easy to open the stat house just two bolt and an O ring
Old Jan 7, 2011 | 05:50 PM
charliekp's Avatar
charliekp
hi huys,its a 1998 model(s reg)..i asked one off the fiter down my works and he said its probably the thermostat?
Old Jan 7, 2011 | 06:00 PM
Chaz888's Avatar
Chaz888
yep would say stats the problem just take it out and replace it very easy job leave main tank cap on you lose less fluid that way and if your short on cash you can just run without it ps you after any tune up part got a 3l throttle body and a unichip intrested?
Old Jan 7, 2011 | 06:07 PM
Chaz888's Avatar
Chaz888
OOpss just though you have to keep the thermostat cos thats how the O ring seal works my bad!!!
Old Jan 7, 2011 | 08:56 PM
charliekp's Avatar
charliekp
chears chaz,i thought it might be the the thermo,im normally good on the cars,not so much ford,vauxhall maybe-used to have a calibra turbo and done an overhaul on that until bottom end went(rings and the rest)....get new thermo in it tomorrow and give it a go.....
Old Jan 17, 2011 | 04:21 AM
carlfiesta999's Avatar
carlfiesta999
checked the waterpumps been changed to a metal impellor one? does anyone know where abouts on the engine the upump is and how hard is it to check/change it?
Old Jan 19, 2011 | 06:26 PM
charliekp's Avatar
charliekp
yes guys,changed the thermo and its running ok at the minute..thanks
Old Jan 19, 2011 | 06:30 PM
charliekp's Avatar
charliekp
Default smokey and alot of condensation
sorry to be a pain guys,are st24s supposed to have a bad condensation problem coming from the exhaust?
any help would be greatfull
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
