fiesta 2002 tdci code reader
Old Jan 5, 2011 | 06:28 PM
LukeDaisley's Avatar
LukeDaisley
Default fiesta 2002 tdci code reader
do you know of a code reader that will work on my fiesta? I have tried 2 different ones now to no avail.
any help will be rewarded with rep points.
thanks luke
Old Jan 6, 2011 | 07:04 AM
oldford's Avatar
oldford
A 2004 diesel must be compliant with EOBD rules. So any cheap EOBD/OBD2 scanner should work.
Are you sure it's a 2004 and not a 2003 model?
If it is a 2004 model then you have a problem in the car. Wiring between diagnostic connector and ecu or a defective ecu.
Which pins are present in the diagnostic connector?
Old Jan 6, 2011 | 05:42 PM
LukeDaisley
2002 sorry.
Old Jan 6, 2011 | 06:07 PM
oldford's Avatar
oldford
2002 TDCI is not EOBD compliant and you need a Ford specific code reader.
Besides factory equipment or expensive after market scanners I only know of this one:
http://www.autoenginuity.com/product...ware.html#EI01
Check with them if your car is supported.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Sp3no
Sep 27, 2015 07:23 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Si B
Sep 12, 2015 06:49 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
