St170 gsxr itb wanted
Old Jan 3, 2011 | 09:06 PM
racerjosh's Avatar
racerjosh
Default St170 gsxr itb wanted
Im after a st170 gsxr itb setup for my 1.6 zetec, can anyone build me one?
I dont have the time to do it so has someone got one for sale or have experience building one?
Old Jan 3, 2011 | 10:30 PM
Sp3no's Avatar
Sp3no
The ST170 GSXR ITB setup uses the first part of the ST170 plastic inlet manfold, this will not fit the 1.6 engine so this setup will no work
Old Jan 4, 2011 | 12:33 PM
racerjosh's Avatar
racerjosh
ah.. so is it for the 1.8/2.0 engine only then?
Old Jan 4, 2011 | 11:27 PM
Sp3no's Avatar
Sp3no
Basically the 2.0L ST170 has a plastic inlet manifold that is in two parts, the part that bolts to the head has silicone hoses on that is perfect for sticking some bike bodies onto. The ST170 manifold will not fit your 1.6 head so to do the conversion you will have to find a suitable way of mounting the bodies to your head. The 1.6 engines are very restrictive so the best thing you could do is up the capacity and buy a bigger engined focus.
Old Jan 4, 2011 | 11:31 PM
dug112y's Avatar
dug112y
passionford pro
it will fit a zetec 1600 but not a zetec se 1600. which engine or car do you have?
if you want it all done for you contact bogg bros or chester sports cars.
Old Jan 4, 2011 | 11:37 PM
Sp3no's Avatar
Sp3no
Never knew that
Old Jan 5, 2011 | 12:10 PM
racerjosh's Avatar
racerjosh
ermmm not sure.. its the same engine as the zetec s in the fiesta .. but il double check
Old Jan 5, 2011 | 12:13 PM
bezo's Avatar
bezo
powered by K26
is your exhaust manifold on the front or back of the engine?
Old Jan 5, 2011 | 12:23 PM
caprizetec170's Avatar
caprizetec170
it will bolt to the head but ports wont line up as there is a 5mm difference in port height
Old Jan 5, 2011 | 01:06 PM
racerjosh's Avatar
racerjosh
just had a check and its not the se engine it just says zetec-s
is there anyway to get the port to line up or will i have to use jenvey bodies?
Old Jan 5, 2011 | 08:33 PM
dug112y's Avatar
dug112y
passionford pro
thats a zetec se engine. you can get a specific manifold for it. contact bogg bross or look on zetec s fiesta website.
Old Jan 5, 2011 | 10:52 PM
racerjosh's Avatar
racerjosh
il be on the phone to bogg bros tomorrow
moesin2005
Jan 23, 2022 06:28 PM
rog
Aug 30, 2015 05:32 PM
track.focus'd
Aug 12, 2015 05:53 PM
adriansaleem
Aug 3, 2015 11:21 AM
