Escort Cab Roof Pump problems
Old Jan 3, 2011 | 03:47 PM
djchurch2001's Avatar
djchurch2001
Default Escort Cab Roof Pump problems
Roof pump on my escort turbo cab no longer working.
1. I know the switch works as i have tested it.
2. When you press the switch i can hear a clicking coming from the relay in the drivers footwell.
3. Changed the 2 green relays on the pump loom itself
4. If i bridge the terminals on the connectors where the green relays go the pump will work. (But only Sometimes)
5. I have checked all the earth points.
Is there anything else i can try. I dont think the pump is broken itself because i can get it to work.
Old Jan 3, 2011 | 04:03 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
its the silver thermal cutout by the sounds of it it should sit in the loom near the pump loom by the 2 green relays hope this helps
Old Jan 3, 2011 | 04:22 PM
djchurch2001
cheers for that, stupid question but what does it look like?
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
carlo
24
Oct 5, 2015 08:20 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
