st170 judders/loss of power when hot??? help!!
Old Jan 3, 2011 | 09:34 AM
pad227's Avatar
pad227
Default st170 judders/loss of power when hot??? help!!
hi all, really starting to bug me now... when the car just starts and say for a good half hour runs like a dream, only when it gets hot starts juddering violently ,this starts around 4500/5000rpm but the longer i drive it the lower down the revs it gets.
just dont understand why this only happens when car is hot? anybody any ideas?? has had new fuel pump, spark plugs, fuel filter, maf sensor checked....
Old Jan 3, 2011 | 10:04 PM
phil_focus's Avatar
phil_focus
have you had it checked for fault codes?
Old Jan 4, 2011 | 04:29 PM
CarParts Express's Avatar
CarParts Express
Possible coil pack and leads breaking down due to heat
Old Jan 5, 2011 | 07:43 PM
wrc62's Avatar
wrc62
It's probably the fuel pump, i had the same problem on my ST170. Problem resolved after changing this pump
Old Jan 8, 2011 | 09:01 PM
alexst0ne's Avatar
alexst0ne
I've got this problem and i've also got a new fuel pump so would be interested to see if there are any other ideas!
Old Jan 10, 2011 | 03:48 PM
Sp3no's Avatar
Sp3no
Coilpack of fuel pump control module
Old Jan 10, 2011 | 03:57 PM
white2lsr's Avatar
white2lsr
Had exactly the same problem with mine. Was the fuel pump control module.
Old Jan 14, 2011 | 11:09 PM
alexst0ne's Avatar
alexst0ne
Well i've already replaced the coilpack so i guess it must be the CM!
Old Jan 14, 2011 | 11:16 PM
white2lsr's Avatar
white2lsr
Have you had diagnostics check done using decent equipment?
Old Jan 14, 2011 | 11:34 PM
alexst0ne's Avatar
alexst0ne
My ex-boss had a program that he got from ebay that i plugged in and it communicated ok, but had no DTCs. Don't know what the official Ford software would say though...
Old Jan 14, 2011 | 11:35 PM
white2lsr's Avatar
white2lsr
Dont bother going to ford. Get an auto electrician who has something like the snap on solus etc to come and do a check. Should cost no more that Ł30-40.
Old Jan 14, 2011 | 11:39 PM
alexst0ne's Avatar
alexst0ne
Thanks for the tip! I've just started a new job at JLR so i'll see if i can make a few friends with some diagnostics type people too
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
