My cheapo brake kit....
Dec 30, 2010 | 05:17 PM
A couple of months ago I asked about Mitsi Evo Brembos on the Focus RS.....
Well here it is all fitted up...!!!
Front discs are EBC Ultimax (up the EBC's!!!!) from a VW Pheaton
360mm x 34mm
Mitsi Evo Brembos (refurbished by Brake Engineering with new seals and pistons).
Ferodo pads.
Customs brackets which I made up from billet alloy.
Total cost was just under £350!!!!!!
Took me in total about 7-8hrs from start to finish to do the whole job.
CheeRS
Steve
Dec 30, 2010 | 05:41 PM
love it, bud
*heads off to ebay in search of cheap brembos...
Dec 30, 2010 | 05:44 PM
Nice work mate
Dec 30, 2010 | 05:51 PM
Resident Wrestling Legend
they look really really good
what wheels sill they fit under though?
and did you redrill the discs or did they come like that?
Dec 30, 2010 | 05:53 PM
The ladies love it French
Nice, but it looks like they're only gonna sweep 60% of the disc at the most?
Dec 30, 2010 | 07:02 PM
The Evo pad is about 40% bigger than the STD Focus RS pad.... I redrilled 2 hole and had to file 2 of the standard holes to convert to 4x108 stud pattern.
Dec 30, 2010 | 08:50 PM
What were they originally 5x112?
Dec 30, 2010 | 09:22 PM
Yes double drilled (as in 10 holes) as 5 x 112
Dec 30, 2010 | 09:45 PM
*** Sierra RS Custard ***
Dec 31, 2010 | 04:14 PM
Nice conversion
Btw do you have any idea if that kind of conversion is possible with a 283mm disc? Using instead of the Evo Brembo's, the Fiat Coupe ones?
Dec 31, 2010 | 09:56 PM
What car and what size wheels???
Jan 1, 2011 | 11:34 AM
It's a 1999 1.6 Petrol Ford Focus with probably 17s, but if it's to much i'll go 16s!
Jan 1, 2011 | 07:32 PM
I'd more than likely use the 300mm disc from the ST170, they should fit with no issues under 16" or 17" alloys
Jan 1, 2011 | 07:34 PM
But what about the thickness of the disc? The Brembo's work better with 26/28mm discs right?
Jan 1, 2011 | 10:17 PM
the discs will be too thin if you use the brembo's
Jan 2, 2011 | 12:20 AM
I've heard about a 283mm discs with 26mm of thickness that are from a Peugeot, i think a 306, but i dunno if they go with the Brembo's...
Jan 2, 2011 | 02:30 PM
Wouldn't worry too much I had some Merc Brembos years ago that originally ran with 32mm discs and used 28mm Focus RS discs
Jan 2, 2011 | 02:32 PM
very nice
Jan 3, 2011 | 09:55 AM
Quote:
Originally Posted by
SteveB
I will then look out for a pair of 283mm discs with 26mm of thickness to go with me Brembo's
And hope that all fits under 16''...fingers crossed! Thanks for the help.
Jan 3, 2011 | 10:35 AM
what are they like?
as standard FRS brakes aint very good IMO.
Jan 3, 2011 | 10:58 AM
Pee vee....always heard good things from Brembo brakes, u don't like it?
Jan 3, 2011 | 11:02 AM
Yeah the evo conversion looks like it will be very good..
I just don't rate the standard focus rs brakes that much.. They work fine, just not as well as i'd hoped for!
Jan 3, 2011 | 11:09 AM
I thought every Brembo's where the same...just had different sizes to fit bigger discs...
Mar 1, 2011 | 05:59 PM
the caliper ? is it from an evo 8 or 9 or what is it ? looking for a good cheap caliper that can handle 355mm disc for my cossie
Mar 1, 2011 | 07:08 PM
EVO 5-9 calipers are all the same. Ive been looking into this for my Celica GT4.
The original disc sizes for these are:
Diameter: 320mm
Height: 43.5mm
Width: 32mm
PCD: 5x114mm
Centre Bore: 67.1mm
Not sure what later Fords run 5 stud though?
Mar 1, 2011 | 07:17 PM
It's cheap, but the weight of those discs is significant.
Mar 1, 2011 | 09:14 PM
Later fords run a 5x108 with the granadas running a 5x112
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
