paddle clutch?resurfaceing
hi people any one had a 6 paddle clutch resurfaced ,i had my scooby one done few years back but carn't find the company was in the north east anyone got any info ?
cheers andy
cheers andy
I know of a place , in Leeds i think, that charge 60 for the paddles, 25 for the pressure plate.
If you want me to find out the details, your best off pm'ing me as i will forget otherwise lol
theres a place near leicester thats done a few 6 paddles for me ,they have done alcon and ap and charge about 80 ,will look for invoice and post name and address later, this is for a reline
Used the following company for years, my five paddle has been done about four times and the 4 paddle a couple. They titalate the springs as well.
James
Industrial Friction Materials
Unit 7
East Moors Business Park
Tel from UK: (029) 2049 9111 / 2049 9121
http://www.industrialfriction.com/home.php?page_id=3
East Moors Road
Ocean Park
Cardiff
CF24 5JX
James
Unit 7
East Moors Road
Ocean Park
Cardiff
CF24 5JX
Will hardly be much more expensive just to buy a new paddle plate.
But there should be clutch places all over the country that can rivet new paddles on. Just make sure they end up the same thickness as the new ones would have been.
And always ensure clutch cover and flywheel surface are perfectly smooth before refitting
the clutch was free mate ,resuface or what every you call it 80quid with delivery
so few hundred quid cheaper, fly wheel will be skimed when bottom end done
Ahh right, you bought a complete clutch kit second hand. Thought you already had a full clutch but wanted the friction plate sorted.
Although you can buy complete new clutch kits for around Ł300 for some makes. Some of the bigger name brands are dearer though.
nar got a 6 paddle clutch plate for free but there quite a bit new so will get it redone still need the other part
By time you get it refaced, buy a flywheel, cover and release bearing...you'd almost be as well just buying a new clutch
And you need to make sure you get a clutch cover to match the paddle thickness. Different brands do use different thicknesses.
You can buy a complete new 3 piece clutch kit for around Ł300 in some cases
And unless aiming for over 400bhp, organic is best.
Although if aiming for over 400bhp, or close to it, dont expect the 5 speed to last long either
i have a fly wheel just not the clutch cover il pick a second had one up and a thrust bearing i can get off motor factors for 30 quid
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
