omex 710 ecu
Old Dec 28, 2010 | 04:30 PM
C05W0RTH's Avatar
C05W0RTH
Default omex 710 ecu
how much would the above ecu be worth second hand?
i'm going to sell me l8 and buy an aftermarket management and have been been offered a omex 710 but not sure what i should pay.
also would new a full new engine loom? i have a ryan loom at the minute, could i just change the ecu plug or buy an adaptor?
Old Dec 28, 2010 | 05:05 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Worthwhile swap, you can simply replace the pins on the loom you have already but you may have to add some extra wiring as there's loads of extra features you may wish to use, I've just done this on my 500. The ECU new is £845 plus vat, you need to be careful that it has the right drivers for what you want though but even if it's the wrong spec it can be sorted cheaply.
You will be able to run coil on plug, 8 inj, launch control etc etc. You will also be able to control your cooling fans with the ecu too.
Old Dec 28, 2010 | 05:36 PM
C05W0RTH's Avatar
C05W0RTH
i believe it has been run on a non turbo car which way running a coil pack.
i will only be using 4 injectors.
how will i know it has the right drivers? he just gave me a link to say it's this ecu.
http://www.omextechnology.co.uk/Ecus/710/omem710.htm
Old Dec 28, 2010 | 05:45 PM
Martin-Hadland
That link is just demonstating what the ecu is capable of NOT what spec yours is! If it's the one on ebay then at that money I would be buying a new one.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
