saph rear diff mount
hi all just wonderd what rear diff mount your using on your saph,ive got all the front end done and now sorting the rear end,
thx all
thx all
Im in the same position at the minute.
Flowflex one, its cheap- & it looks cheap.
Motorsport developments one looks good and resonable price.
GGR one looks good too, abit dearer-worth the extra?
Inputs please
Inputs please
I've got an Msd one, haven't had the chance to try it yet but it looks really well made and I've heard nothing but good things about them
I have got the GGR diff mount as said it is made out of one piece of billet but I Had to adapt the upper bush bolt because it was hitting the ARB on mine, Motorsport developments one looks of equal quality with the added advantage of having the flush mounted bolts to solve this problem, I also fitted a 2wd Vibe-Tech gearbox mount on mine and some of Stu's Collins Engine mounts, all the above are the best mod I have done on it so far it vastly improves how the car feels.
PassionFords Creator
The best one piece CNC'd mount is this one:
http://www.shop.motorsport-developme...duct-158-p.asp
(Nice big pics on there too)
Act now with your discount code of PFTDiscount for 10% off and beat the vat too so 12.5% off between now and Midnight NYE.
you could just countersink the bush back plate but I didn't want to risk this because it is not thick enough and would probably weaken the fixing, to be quit honest I wish I had got mine from Motorsport developments it would of saved a lot of time and hassle, the only reason I got the GGR mount is because I was passing that way and wanted to lighten my wallet a bit "the last sentence is a lie because I stuck it on my Visa and increased my Debt some more
I have got some pics somewhere will find them if you want?
you need to get a bolt with a countersunk head make sure it has got the same tensile strength or higher than the original one, then I found a large diameter plate washer which was about three to four mm thick and countersink this so the new bolt sits flush.
http://bbs.rsownersclub.co.uk/showthread.php?t=313474
Has any else found that these transmit more noise into the car?
My car is a road car but with a plated diff but i found mine to be too loud so i have now gone back to standard type (well a escos one instead of sierra one) but have not run car since
As I have said before the way it drives now is fantastic and with the gearbox mount the gear change is now nice and tight it has lost all the sloppy feeling, I have fallen in love with it again.
I tried the MC racing one without a roll bar for 3 months, despite having no arb it had way less roll than a std bush with a std 16mm roll bar, it stopped all the rear steering attitude.
Noise wise there was an increase in noise, but no more really than having a noisy set of tyres, it did produce a drumming sound at 65mph, this was the tank when 3/4 full at 65mph it resonates, I applied a stucko pad to the tank to change the resonant frequency and it hasn't done it since.
There is still the slight noise there, but very well worth it, it's so slight after a few days you forget about it.
I use a std new box mount and std engine mounts as don't want vibration when I don't have to put up with it.
Hi Gav
I have the R&B type and I only noticed a very slight amount more noise - not enough for the family to notice or complain about on a 70 mile trip to the beach. Did you have the mount done at the same time as the diff?
never had 1 but the msd 1 looks like a nice bit of kit,
think i might invest in 1 for my saph going back on the road next year, got solid beam mounts to so should improve it a bit
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
