Turbo cam timing
Just wondering what your thoughts are camshaft timing on turbo engines.
Do you run less overlap to stop boost escaping down the exhaust or more to flush out spent gases ???
Engine is a zetec st170 with standard cams vvt removed and adjustable pulleys fitted
removed it cause ecu i have(omex 600) cant run it properly as its not just an on off switch its constantly adjusting that and had it on carbs before so couldn't jet it with it working
I thought the 600 could run it, maybe its the 710 i'm thinking of that can deffo run it ok. it's well worth having though!
Re cam timing - the way i'd do it is set it up on a RR with as little boost as possible and find what setting makes the best peak power, how else would you know what's benefiting the engine and what's losing you power?
muz
Aug 16, 2015 12:57 PM
