rs2000 engine into a fiesta mk5??????
Old Dec 26, 2010 | 12:05 AM
ranzrs's Avatar
ranzrs
Default rs2000 engine into a fiesta mk5??????
has any1 put a rs2000 engine into a mk5 fiesta?
if so, bit of info please, i.e. wiring loom, mounts etc?
just generel info really as im thinking about doing it as i have a rs2000 engine box loom ecu etc..
thanks
Old Dec 26, 2010 | 09:22 AM
Oranoco's Avatar
Oranoco
As per post on Mk4 thread. Don't bother, sell the RS2k bundle and fit something else, the I4 is a big old boat anchor
Old Dec 26, 2010 | 09:29 AM
Rs Gary's Avatar
Rs Gary
as in other post go to www.rs2000-16v.com for info and my standard i4 gives out 160bhp and 154 ft lbs of torque so not a bad anchor lol
cheeRS gary
AKA shrek
Old Dec 26, 2010 | 09:46 AM
Oranoco's Avatar
Oranoco
Not a bad figure for standard, most of the ones I have seen struggle past the 140 mark. The engine is also very heavy compared to something like a 2litre Zetec.
I would be looking at something like an ST170 motor which humps the I4 in every aspect. Not a straightforward fit as we have found but has so far been found to be exceptional and it's only in a running state at the moment until the throttle bodies and management goes on. Mate is putting one in a Ka so I see no reason why it shouldn't go in a Fiesta
Old Dec 26, 2010 | 09:50 AM
Mr.T's Avatar
Mr.T
cheeRS gary
AKA shrek
You need those HP to get all that weight forward
Better off with a Zetec. easy to get and easy to tune turbo wise.
Old Dec 26, 2010 | 10:35 AM
Mark_'s Avatar
Mark_
as already said above jump onto rs2000-16v good info on there regarding the 'heavy old boat anchor'
a few turbo I4's aswell with good results for far less than you would think
Old Dec 26, 2010 | 09:34 PM
Rs Gary's Avatar
Rs Gary
dont say that MAR K all the passionford experts will tell you that you are wrong and that the i4 weighs a least 2 ton and CAN NOT BE TUNED
Old Dec 26, 2010 | 10:01 PM
sheeks's Avatar
sheeks
just fit a puma lump and tune it up some. great cars when done right , pop on www.zsoc.com for more info on engine swaps.
Old Dec 26, 2010 | 10:59 PM
Oranoco's Avatar
Oranoco
It IS a heavy engine but nobody said it can't be tuned. I'm fond of the RS2k which puts me in a minority round here. The unit isn't a desperately good one though for a transplant with the other options open.
Old Dec 26, 2010 | 11:21 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
I like the sound of the i4 lumps, but, would personally go zetec, due to the options involving turbos.
Old Dec 27, 2010 | 04:58 PM
lozi's Avatar
lozi
My Cossie Ate My Money
Alot of people are saying zetec but i was under the impression putting a bigger zetec in a Mk5 was so hard it wasnt worth the bother, thats why people all do puma conversions?
Old Dec 27, 2010 | 05:32 PM
rsfido_1989's Avatar
rsfido_1989
You well need custom engine mount and change the bell housing or gearbox for starters.... But you will do the same with i4 lump..... Im measuring up zetec and cvh blocks at for a turbo conversion.... Its easier than you might think
JoeyBoyden
Jan 4, 2024 02:36 PM
Pwrs2k
120
Oct 16, 2015 03:16 PM
RockinRein
Aug 19, 2015 07:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
