Sluggish Mondeo
Old Dec 25, 2010 | 01:15 PM
Jessop's Avatar
Jessop
Default Sluggish Mondeo
Does anyone know what could be causing my Mondeo to be a bit sluggish and use quite a bit of petrol? I've not seen over 30mpg no matter how carefull I drive. My sister has the same model ( MK2 LX 1.8) and has had over 40 on a long run! Plus it is quicker than mine and mine has been looked after considerably better
Old Dec 25, 2010 | 02:11 PM
oldford's Avatar
oldford
Defective sensor or some air leak in inlet- or exhaust-manifold.
Check exhaust manifold and gaskets, check inlet manifold and gaskets and vacuum lines.
If all is well have the dealer check the sensors.
Old Dec 27, 2010 | 07:01 PM
Jessop's Avatar
Jessop
Thanks....Will check for air leaks in morning
Old Dec 27, 2010 | 07:09 PM
dojj's Avatar
dojj
Resident Wrestling Legend
blocked cat or some dodgy plugs/leads
Old Dec 27, 2010 | 08:13 PM
jamie's's Avatar
jamie's
how does it run/drive?
any hesitation, splutters misfires under load etc?
they're bad for coil packs/leads/plugs
cats can break up and got blocked
coolant temp sensor?
Old Dec 31, 2010 | 03:55 PM
forevaford's Avatar
forevaford
id say cat,
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
