picture of 9inch diff without the diff hanger?
Im looking for pictures of the 9inch diff without the diff mount.
The interresting bit is what it looks like behind this mount as on the wrc cars they machine away those tapets.
Im about to buy a 9inch from a wrc car but i need to use the gpa diffmount on my car.
So i need to know if it is much hassle to fix, or maybe bara exchanges lids?
Hi,
Had the same problem on our car. Ours had been hacked off so milled it flat and put two m10 threads in the cover. And take the distance up with a spacer. Al try and get a photo sorted over the weekend
cheeRS jim
cheeRS jim
mark
heres our rear rear diff cover,hope it helps
DSCF0193.jpg?t=1293198273
is it a gpa car youve got?
Thats perfect Jim, thanks.
its for my focus with gpa rear end
https://passionford.com/forum/restor...ian-focus.html
that looks a bit like the 8.8 that i have in my kitcar, have you got a less close up pic, where do these 9" diffs come from originally, i know the americans fit the 8.8 just wondering if it is the 8.8 and its just called a 9" over in uk
DSCF0155.jpg?t=1293298175
as far as i know these were only built for motorsport by FF DEVOLPMENTS for ford
how the 8.8 is fitted http://www.key-ideas.com/DGKurTwo2-040604-8.8LSD.html
Ł830ish for complete new 8.8 with 3.55 ratio and LSD, should be good for way more HP than any cosworth can chuck at it.
http://cgi.ebay.com/ebaymotors/NEW-0...Q5fAccessories
i've got a pic of a solid mount rear plate where the plate and diff mount are all cast in one, so you literally bolt the diff cover to the diff, and then the cover to the underneath of the car
can't find the pic though but i'm sure someone will know what i'm on about
not sure, but i'm fairly certain it could easily be replicated by the likes of cdf as a plate that sits ontop of the original diff plate bolts and bolts to the car without the need for a diff hanger
in fact, you could make one side for one, one side for the other and the bit that goes in the top and it could all simply bolt together along the top somewhere, just need some longer bolts for the diff cover plate and job jobbed
That's it. Ideal for grpn/standard cars. No gud for grpa mounts different in the shell. HUD mod to do is fit the upper front mount when using a grpa beam, had these Diffs twist out the beam! Hard to get hold of so we had to fab one up
don't know, at a guess as its seems to be a common conversion in the states, the original drive shafts may fit, are the sierra shafts stubby bit that the main shaft bolt to 28 spline by any chance, or 31 spline
looks like u use mustang cobra shafts with cosworth ends at the wheels end, maybe it would be a little costly by the time its all done, but it would be very strong, here is the cobra shafts next to standard cosworth ones, i'm using the 8.8 and cobra shafts in my kit so took a photo of the difference compared to cosworth, photo doesn't show it very good, but the cobra are about 2x the thickness of the cosworth shaft
cobra is the new shaft and the cosworth is the old shaft
think the sierra ones is a 26 spline, but don't quote me on that as it's been a while since i counted them
yes it just slides in and i guess from what i read about changing the end by the wheel that must be the only bit you change, don't know if that would be the weak link then, i have seen uprated cobra shafts rated at 900hp, and being america that would more than likely be 900 at the wheels
they are a lot, but you buy the diff and shafts and everything as a package, i'll look for a price, although you can buy a complete rear IRS setup from a used car, for good money
here are a few complete setups from scrap cars, the 03/04 cobra was the supercharged 400+hp car.
http://cgi.ebay.com/ebaymotors/03-04...Q5fAccessories
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
this is where i got my stuff from.
http://www.fortesparts.com/product_i...roducts_id=229
but can't find the shafts
ford explorers over in the states has the same IRS, here is an open diff one very cheap, but you maybe
http://cgi.ebay.com/ebaymotors/Explo...Q5fAccessories
but if the explorer has irs in the states, maybe it has irs in uk, and you would be able to get the parts from a late scrap explorer.
looks like the explorer option is out, they got irs in 2002, ford stopped selling them in 2002 so i guess the irs explorer never got to the uk, thunderbird irs is the same, so lots of options though
Clearly no thought was given to "productionising" the swap.
The IRS 8.8 has a number of problems: It's BIG and WIIIIIDE, the output things are cups for plunging tri-pode bearings--like the front of Sierra 4x4---, the diffs are crap with only 2 planet gears (although better--but still 2 pinion---diffs are available for less that $300)
The "cup for plunging tri-bearing" and the width cause the main problems of how to mate the half-shafts inner CV up.
The solutions were custom dhalf-shafts and custom output flanges for the real bargain, oh I'm gonna rush out today and buy an 8.8 for $50 price of around 1200 bucks US..
That is absurd right there.
I read you must buy some special diff cover in cast alloy for the mount up---another mere $175
All told I've read---obviously I have followed the madness---as it is indeed madeness----and seen people talking the total cost of the "easy and cheap" Ford 8.8 costing over $2000 to do..
Bugger that!
I looked at and rejected the idea--pulled one of the units out of a fresh crashed Thunderbird--back in 1989 and saw too many problems requiring too many dollars to overcome them..
And started look at the uber-strong, 4 pinion diff multi-disc LSD in the heavy and powerful 3 liter turbo Supras.. Heavy stresses geas, and power stresses gears, and the US versions of the MA70, MkIII Supra are 3,0 or turbo power and huge barges weighing in the mid 3000-lbs range. And time have proven their 8" unit to be fine even in high budget modded drift-o cars with claimed 700 bhp...
No problems...
Seems the everyman's solution...
There's even a kit to stick 'em in very affordably.
Nope the 8.8 is big, and bulky and even those whop have them in our XR4Tis have said, "I wouln't do it again---I'm thinking of the Supra conversion"..
all i know is from looking into it, they are plenty strong enough for a cosworth application and as they are readily available good used with drive shafts and factory lsd (not the best lsd), and the info is online to do the conversion, with the number of options in ratio and lsd, it would be a good option, they can't be any bigger than the 9" thats being used in the high end conversions, if the wheel end is the only bit that needs changing, the shafts can be made the correct length at the same time, doesn't seem a bad idea to me, i have the setup in the back of my kit, and will be using the 8.8 front out of a lincoln navigator to give me 4x4 next year
Kiran1600E
11
Oct 2, 2015 11:35 AM
DavidK
Sep 27, 2015 02:55 PM
